Free lime
   / Free lime #1
tile
Bronze Member
Florida
Hi guys.
I have the opportunity to get lots of free lime from one of the citys thats close by.
I am told they use it as when the water comes out of there pump station it first
gos in to a lime then off to the other treatments.
So is it worth getting or should I do a soil test first.
Also could it be used on a road or for filling in holes around here?
Thanks Ron.
   / Free lime #2
Mornin Ron,
If its free and you have acidic soil then its worth it to get some ! Find anyone with a bunch of oaks on their property and they would be glad to help take some of it off your hands ! ;)
   / Free lime #3
scott_vt said:
Mornin Ron,
Or someone with fir and pine trees that they want to grow grass under. hte shed needles make the soil acidic and the grass dosn'r row well. put down a little lime and the grass perks right up:) the lime I have experience with would not be good road filler, it is like fine sand when groke up.
   / Free lime #4
tile said:
Hi guys.
Thanks Ron.
You should get a soil test, first. Why put down something that you may not need? :confused:
   / Free lime #5
tile said:
Hi guys.
Thanks Ron.
I'm no expert, but it sounds to me like you're talking about lime cake, or wastewater treatment sludge, as opposed to lime. I know that around here treatment plants are always looking for someone to take this off their hands. Lots of issues involved with accepting this material. I would definitely do some research first.
Also, remember that it's a lot harder to reduce ph in an overlimed soil than to increase ph in an acidic soil, so I would definitely apply lime only after a soil test to determine the proper rate.
   / Free lime #6
i got the impresion he was talking about FRESH water treatment... as you pump it OUT of the ground... not effluent treatment...
i thought that was a simple as add horse manure..... (the more raw, the better for changing PH which is why you normally want to compost it for a bit before hand)
   / Free lime
Hi guys.
Thanks for all the info I will get the soil test befor I start getting any of this stuff.
And yes it is from a fresh water treatment plant.
Ron.
   / Free lime #8
Lime is used to take the rust out of the water.
   / Free lime #10
I have very acidic soil due to all of the fir and cedar trees on my property.
Just as a side note, when I was remodeling my shop, I took all of the drywall (gypsum board) and tilled it into the lawn and garden areas. Didn't have any paint on it, and I don't know how that would affect things, but the new lawn turned out great, and it is a cheap source for fertilizer.
2008 Ford F-250 Reading Service Truck (A55788)
2008 Ford F-250...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
PALLET OF SCAFFOLDING (APPROX. 7 PC) (A52706)
PALLET OF...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
