Free cheesy wheel horse... any potential?
   / Free cheesy wheel horse... any potential? #1
littleman456
Mn
Toro 16hp wheel horse
Well I got this wheel horse for free through the family, for some reason the oil has a tendency to sometimes leak oil into the piston. Well I think it's the rings but that's not why I made this post. The reason I originally wanted this thing was to move my jet ski trailer around the yard. I ride a JS550 and a Wavejammer, both weigh about 300 pounds fully loaded. The trailer is probably somewhere around 200 pounds, it's a 4x6 tilting flatbed garden trailer that I put 2x4 bunks on. My question is: would it be worth fabricating a 2" ball mount to the tractor (I can weld and make just about anything) to move the trailer around the yard? Another idea one of my freinds had was possibly lowering the drive gear ratio so that I could actually launch the skis using the mower as I live across the street from a landing. So basically, how much power/towing capability does one of these have, and is there any way to increase it?
Thanks,
Chase
(I'll try and post pics tomorrow)
Any help? I was just thinking of adding a 2-3" larger pulley on the one end, and a 2-3" pulley on the other end. My main concern is the hydro static drive as they are known for not being the toughest drives out there.
Thanks,
Chase
   / Free cheesy wheel horse... any potential? #3
have you tried moving the trailer and jet skis with the wheel horse without changing the gear ratio, if it has enough traction it will probably pull them fine
I'm not worried about it pulling the skis and trailer as it is a very easy trailer to move (I can just lift the tounge and push it around the yard no problem) I'm just worried about it at the launch. Maybe I'm just over thinking it. I re-built the carb today, so maybe I should try it tomorrow.
Thanks,
Chase
   / Free cheesy wheel horse... any potential? #5
What model is the Wheel Horse, what's the hp? Gear or hydro? The older garden tractors pull great and are often used in tractor pull contests. Most had solid, cast iron rear ends. The cheaper lawn tractors, well not so much. So, it really depends on what model it is.
Yeah CHD, that's kind of my problem, I'm not too sure on the model but I know it's about four years old, 16HP briggs, hydro...I'm thinkin' this one is going on craigslist.
Thanks,
Chase
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
2025 Splash 20ft T/A Flatbed Tilt Trailer (A52377)
2025 Splash 20ft...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
Case 1020 25ft Draper Head (A55301)
Case 1020 25ft...
