Free 3D modeling
   / Free 3D modeling #11
Having seen the original AutoCAD 1.x and the somewhat ready for prime time 2.5x, and using AutoCAD to make a living since Release 9 through AutoCAD 2004; I have seen Autodesk become more money grubbing with each new release. Although I no longer make a living as a CADD Dweeb on a regular basis, I still keep my software current because the new seat cost is prohibitive. Autodesk pretty much forces one to use their subscription program as they have timed new releases in such a manner to make the subscription semi-attractive. I've seen small firms put off upgrading and they get sticker shock when Autodesk no longer supports a specific release and earlier forcing companies to pay full freight for each new seat instead of the upgrade price when upgrade time does come around. Like the Fram man says, "You can pay me now, or pay me later."
Just as AutoCAD became the de facto CADD program and format standard for general drafting; it appears that SolidWorks has become the de facto standard for machine parts and similar design work. I know Autodesk has had Inventor out for some years now; but I don't know if they've been able to dent SolidWorks commanding market share in the MCAD (Mechanical CAD) field.
Also Autodesk purchased a company called Revit a few years back and they seem to be pushing that program for the architectural and building disciplines. Again, I don't know how successful that push is going for them.
I do use AutoCAD's (2008) 3D capabilities, and although they have improved; there is still limited solid editing capabilities, which makes it difficult to make changes to a design as it evolves.
Since I've been away from the business, I don't know if the MCAD companies that made SolidEdge and IronCAD are still around. If one is just goofing around with a CADD program with or without 3D capability, then a low cost or freebie program is probably OK. But if one makes a living using design software, I truly suggest sticking with a name brand product with a track record. There is nothing worse than committing to a CADD product that is orphaned because the company that made it went belly up and you can't import your CADD files into a different program.
I started with CADD in 1979 using Auto-Trol GS-100 through their Series 5000 software. I've seen and briefly used the long defunct Terak software back in the early 80's that was a knock off of Auto-Trol. Auto-Trol is still in business; but not as a CADD hardware/software manufacturer. I've used AutoCad since R9, and seen demos of Solidworks and Pro-Engineer. I've used Intergraph/Microstation through V3 and hated every moment of working with that software. Microstation is at V8 I believe. As I recall Autodesk bought TurboCad many years ago. I've also messed around with 3DS MAX from Autodesk. I could ramble on; but I've done enough for now.
   / Free 3D modeling #12
Server1 and Server2 are just 2 different places to downlaod the software from.
THe torrent mirror is another way to get the software via peer-to-peer software program which you really dont need to worry about.
Just click on server1 or server2.
   / Free 3D modeling #13
Thanks I'm going to download tonight and play around.
Thanks again, Lee
   / Free 3D modeling #14
Thanks guys I have been looking for a CAD program. Like many others I have been using AutoCAD for years. I believe I started using it in Version 12 DOS. I have been away from for awhile and could not believe the price for the LT version.
On another note AUTOCAD is not the only money grubber out there. SDS a steel detailing software has developed and done the same thing that AutoCAD has. Real good service in their early years with reasonable pricing. Now that they have become the premier steel detailing software all bets are off.
   / Free 3D modeling #15
I am an old Generic cad user/geezer and want some thing like it!
Commands were so easy like ZI= zoom in not like autocad were you have to type 1/2 a sentance a answer 30 questions to draw a line.
any suggestions
tom
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2008 Dodge Ram 1500 Single Cab Pickup Truck (A55973)
2008 Dodge Ram...
