Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 3,939
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Jomar,
With your stated uses digging around a house foundation, doing dirt work, and driveway refurbish then based on your experience with the full size machines you will want a machine in the L35-L48 size. For digging around a house foundation smaller is better but if you have experience running a BH that will help.
The B21-B26 TLB will get it done and just take a little longer to finish.
Some other considerations;
- Storage/Garage - the L-35-39-48 will all be over 8' clearance so you will need a 9' high door.
- The L35-48 series usually have a fixed front bucket (no quick attach) the L39 and L45 have a QA bucket - this is important if you want to have forks, bale spear or use other QA attachments
- The L35-48 usually dont have a hydraulic thumb but a mechanical one - and the newer L39-45 can have a hyd thumb setup
I say "usually" the older Kubota L series TLB dont have these options - they may have been added so its possible you will find a QA bucket or hyd thumb on the older ones - its not typical tho.
Bottom line it comes down to $ if you can afford a newer machine L39 I would go that route otherwise you can find a L48 for high teens to mid $20K range.
