FPPF does any body use this in there tractors
   / FPPF does any body use this in there tractors #1
Terry Stewart
PA.
CubCadet 1864 455 john deere 1960 international lowboy 104 cub cadet
any members use FPPF total power in their older diesel tractors for the lubrication of the rotary pumps?:confused3:
   / FPPF does any body use this in there tractors #2
I have used it in my Duramax and Cat diesel powered motorhome. It is supposed to be good stuff. I have several otr trucker buds that swear by it.
You will get many opinions on this site regarding additives. I personally use the additives because I do not trust the fuel manufacturers and because of the horror stories some of my diesel mechanic friends tell me.
I use hho for my tractors, treat that too. My fuel supplier says hho here is not ulsd yet, but it is coming.
Thanks, I have a 855 case/david brown 1984 model which has a rotary pump, been using off road diesel
with lucas additive, but heard about FPPF and just thought I would give it a try.
   / FPPF does any body use this in there tractors #5
I use FPPF Polar power for low temperatures. It seems to work well.
   / FPPF does any body use this in there tractors #6
I haven't used it, but it routinely got great reveiws on BITOG.
For my diesels I use a blend of Power Service and 2 cycle oil, at a mix rate of however I feel that day. I see no difference and I'm undoubtly over applying, but I haven't seen any negative effects either. Of course, I don't run any of them much, so the rotary pump in my dumptruck is probably junk from mearly sitting around so long (hasn't turned over in 2 years).
   / FPPF does any body use this in there tractors #7
I have used it in my Duramax and Cat diesel powered motorhome. It is supposed to be good stuff. I have several otr trucker buds that swear by it. You will get many opinions on this site regarding additives. I personally use the additives because I do not trust the fuel manufacturers and because of the horror stories some of my diesel mechanic friends tell me. I use hho for my tractors, treat that too. My fuel supplier says hho here is not ulsd yet, but it is coming.
There is only 1 fuel now days .Everything is U L S D .
   / FPPF does any body use this in there tractors #8
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
1264 (A50490)
1264 (A50490)
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
