Four Wheel Drive
/ Four Wheel Drive #41
I agree that there is more wear on the drive system running in 4wd (FWA, MFWD). I understand the wear cost and there will be some. The real issue for me in running in 4wd while using my CUT and SCUT tractor is safety. I can repair a machine. Operating in hilly or steep areas it needs to be in 4wd for safety. IMHO :)
+1 on this, I only operated my old B7500 enough in 2WD to know I did not want to do that again. 8 years in 4WD no problems. IMHO 2WD is for people on flat ground.
James K0UA
/ Four Wheel Drive #42
I use 2WD 80% of the time. I use 4WD when the situation warrants it.
/ Four Wheel Drive #43
I've been mowing since my last post. Just in for lunch. I only had to lock the rear diff about 8 or 10 times. Almost popped a wheelie one of those times. Who sez mowing has to be boring? (But then, it's not really boring if I have my audio books.)
/ Four Wheel Drive #44
My rule always has been to use 4WD to get myself out of trouble, not into it!
I thought MULES used 4 Feet / Hoof drive all the time. Live & learn. :laughing::D
/ Four Wheel Drive #45
any time one of my tractors leave the road i tell them to put the front wheel assist on. now my harvest equipment i only run them when needed.
/ Four Wheel Drive #46
Yeah but what do you know, heck you like Clint Eastwood!!! ;););)
Clint's the MAN!!! :thumbsup:
/ Four Wheel Drive #47
Braking.
larry
TRUE THAT!!! After sliding down a steep grade with the brush cutter on in 2wd I came to fully understand what you are saying!!! :laughing:
/ Four Wheel Drive #48
Braking is a good point...but using lower gears or range helps. Always a good idea to start down slow rather then try to brake so you get the maximum engine braking...this applies to both 2WD and 4WD applications.
/ Four Wheel Drive #49
My Mahindra has almost no front lead. Sure wish it had more for side hilll work. Actually Ive not done a test to see if they lead or trail. I just know that there is a small bind going straight and all it takes to disengage is let off the throttle. Im going to have to check whether it has lead or trail.
larry
Larry I would guess it's lead. But sounds like it's minimal. My little JD2210 has dramatic lead time. when I'm mowing the road bank in 4wd the front tires are clawing all the time. My Kubota's not as noticeable but as I said it'll still bind up and usually I can disengage using your throttle method.
/ Four Wheel Drive #50
What Larry and I are talking about can't be fixed with lower gearing. It's when the rear tires let loose and are sliding/slipping down the hill. 4wd removes all that. The front tires have all the weight on them and will not slip as easily.
But then I have the times when I'm an idiot and trying to work on slopes that are muddy and slick. Sliding out of control down a timbered trail with all four tires sliding is NOT fun!!! TREE!!!!! :ashamed:
/ Four Wheel Drive #51
That "braking" benefit would be applicable to engine or regular. Any [forward] "braking" situation transfers groundforce to the front wheels while subtracting equally from the rear.
larry
/ Four Wheel Drive #52
Can't say I've ever had the rear tires break loose (other then on wet grass...and the fronts were slipping too, so 4WD wasn't a help).
As long as I had control starting down slope...even in 2WD, never lost it otherwise (except for the wet grass...once).
4Wd is great, but it's not a cure for all circumstances.
/ Four Wheel Drive #53
I have had it happen Roy, in 2WD with a B7500DT in 2nd gear going down a hill on the road, throttle down to about 1200 rpm with a load of gravel in the bucket held low. I had been down the road many times in 4WD and got to thinking I should really be in 2WD to minimize wear and tear on the front. The compression (engine) braking caused the rear tires to slide on the road (the road had some small gravel on top of it) once they start to slip the slipping and sliding gets worse as the speed increases. With 4WD the breaking loose will not occur in the first place, as the engine braking has more tire surface to work with in the first place, and the tractor goes down the hill in a controlled manner. I will swap wear and tear on tires and driveline components to an uncontrolled slide.
James K0UA
/ Four Wheel Drive #54
That's just how I feel about it. I usually remember that I had put it into 2WD when I get out of whack. Hopefully, it's not too late.
Maybe the problem with needing to be in four wheel most of the time is expecting to be in it when I'm not.
I've done a complete front axle rebuild so I know I can do it if I have to.
It seems that my new LS's fronts don't claw as aggressively as my old Cub Cadet did. With more weight and a larger footprint, that's probably about right for the difference.
/ Four Wheel Drive #55
James K0UA
Good point!!
Question now is, did you have ballast on the rear? If I'm using my bucket, I have the ballast box on the 3PH. Although I've never had to do this (yet), if I had a bucket load and no rear ballast, I'd probably back down the slope.
Maybe I've just been lucky (except for the slide down wet grass).
/ Four Wheel Drive #56
Good point!!
I had an implement on the back, but probably not enough weight, I know more about having enough weight on the back than I did then. But you can bet it was in 4WD for the rest of the many trips I made down the hill that day! ( after I stopped and cleaned the seat:D)
James K0UA
/ Four Wheel Drive #58
Good point!!
Ballast smallast, steep enough hill and you need 4wd.
Sometimes on here I forget that different people work in different circumstances. For me most of my loader work is done in steep timber land. When I'm on flat/semi flat ground I dont pay so much attention. But when I go into the timber it's 4wd all the way.
/ Four Wheel Drive #59
The second bolded sentence explains why the first bolded phrase was a foolish thing to write...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2022 John Deere 410R Sprayer (A63111)
2022 John Deere...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2015 Hagie STS 12 Sprayer (A63111)
2015 Hagie STS 12...
2014 Ford Escape 4WD SUV (A61574)
2014 Ford Escape...
