Rake Found these used rakes on Craigslist - whacha think?
   / Found these used rakes on Craigslist - whacha think? #1
WaterDawg
Poultney
Kioti CS2410
I found this ad on craigslist.
I'm looking for a used rake with wheels for spreading gravel and topsoil and a rear blade.
Don't know, but these prices seem high.
I have a Cat 1 700lb 3 point hitch>
THREE POINT IMPELLMENTS
   / Found these used rakes on Craigslist - whacha think? #2
Used rakes with gauge wheels are pretty rare. If you want it, better jump on it. Looks good enough in the photo. Those rakes should weight about 300 lbs or so.
I actually have a York Rake TA-1 right now that I had towed behind the old Sears Lawn Tractor.
Part of me hates to give that up, but I'd prefer one I can hook to the 3 point hitch so I can raise it.
   / Found these used rakes on Craigslist - whacha think? #4
It is hard to make a pile if you are just pulling. The only problem I see is you are going to waste another 100.00 trying to find a cheaper one.
Oh, I am sure I want the one that will mount to my 3 point hitch. Not sure what you mean by waste another $100 though?
   / Found these used rakes on Craigslist - whacha think? #6
Can you spin it around to push with it and not take it off the tractor when you do that? Longer booms allow that
   / Found these used rakes on Craigslist - whacha think? #7
I have a 5' Woods rake I got at an auction...Think I paid $250 + the auction fees and taxes...
I priced OEM gauge wheels and IIRCC...they wanted close to $400 for wheels and related hardware...
I have asked the same question on several "rake/wheel" threads and have never gotten a real answer (or I missed it)...
Are gauge wheels of any benefit when mostly using hydraulic tilt to keep the rake parallel with the working surface?
Another question for rake/wheel users...if you change the aggressiveness of the rake (adjust top link) do you also have to adjust the height of the wheels?
/pine
I spoke to my farmer neighbor today about various attachments. He agreed, a landscape rake with wheels is ideal for fine grading be it gravel or topsoil.
He too felt the price was good as well.
And yes, wheel kits run $300+
As for your other question....no idea.
   / Found these used rakes on Craigslist - whacha think? #9
it looks good to me I'd buy it myself if it were closer, I'm looking for the same set up good luck
   / Found these used rakes on Craigslist - whacha think? #10
Don't profess to being an expert. The wheels have to be raised if you want the rake to dig. And they set the digging depth. The advantage of the wheels over using just the lift is that the wheels will keep the rake teeth at a set level even if the tractor is at a different angle on varying terrain. The wheels let you level a soft/loose surface without concern for terrain. I think the wheels are a must in order to get maximum utility out of the rake.
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2017 Ford T350 van (A55973)
2017 Ford T350 van...
19010 (A55851)
19010 (A55851)
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
