Found something strange on my BX23S Fuel Injection Pump
   / Found something strange on my BX23S Fuel Injection Pump #1
BX23S-1
Platinum Member
No Clue
Kubota BX23S
I noticed this weird thing on the backside of my injection pump. This little thingamajig just sits there and spins and rattles around, so look at the picture and see if any of you know what this is. It faces towards the rear of the engine, towards the radiator. Its loose and just spins freely while the engine runs. It has a flat only on one side of it, looks like some sort of pin inside of the middle of it. It looks like it has something to do with the injection pump, but i`m clueless to what it is. I`m just concerned that it sits there spinning from engine vibrations.
   / Found something strange on my BX23S Fuel Injection Pump #2
When I get some time I'll if its the same on mine.
GenLee, if you find it, see if yours is just loose and spins around too.
If yours is the same, i`m not gonna worry about it. But it would still intrest me in knowing what it is.
   / Found something strange on my BX23S Fuel Injection Pump #4
I think it's the anti-tamper cover for the FIP adjustment? It spins so the screw it covers doesn't. Leave it alone.
:wrench:
   / Found something strange on my BX23S Fuel Injection Pump #5
Yep, mine spins. I didn't check it while engine was on. Found it, felt it and it's loose
Thanks for looking into it GenLee, i feel alot better about it knowing others have the same thing.
:wrench:
Thanks, and i have absolutely no intentions of messing with it.
If i dont know what something is, i dont touch it, i always ask others first.
I was just curious as to what it is and what it does because it just sits there spinning/rattling around.
   / Found something strange on my BX23S Fuel Injection Pump #8
No problem. Its good to be able to check with others about things on the same model tractor.
12 in Small Excavator Bucket (A52377)
12 in Small...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
(1) 24ft Free Standing Panel (A51573)
(1) 24ft Free...
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
