Found out the ROPS works
   / Found out the ROPS works #1
daTeacha
Funk, Ohio
... to put a dent in the garage door trim!
   / Found out the ROPS works #2
So did the brakes fail, or was it due to all the ice and snow on the ground and you slid into it?
   / Found out the ROPS works #6
it happens so much it's almost a right of passage. and yes, i've done it.... that's what i get for assuming i built my garage doorheader tall enough
   / Found out the ROPS works #7
I did the same thing the very first time I got my 4010 home. Very embarrasing.
   / Found out the ROPS works #8
Me Too!!!! I was trying to keep the heat in the garage.. Door opened enough for me to clear, but forgot the ROPS.. I knocked the first set of rollers out of the track.. OOOPS :)
Then the next time I'm backing out of the garage and started to turn the wheel and wack... Trim on side of the garage got wacked by the bucket..
Stupid is as stupid does..
2 Great Quotes..
"Experience is gained shortly after it is needed"
"Old and wise only comes after young and stupid"
BUT, It appears I'm not the only one... LOL
Phil
   / Found out the ROPS works #9
Billy_S said:
That pretty much leaves "stupid." :)
ROFLMAO
I must admit that with that subject line I was much more concerned for your safety after a roll over. It's is nice not to have to worry about garage doors. I think the doors on my round-top are 12 footers...:D A R72 Gleaner will fit in there anyway.
   / Found out the ROPS works #10
Were you backing in?...does give sinking feeling in the stomach. :(
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
23169 (A50324)
23169 (A50324)
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A53843)
2021 ALLMAND BROS...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
