Oil & Fuel Found out about fuel filters today
   / Found out about fuel filters today #1
joes_427_vette
Veteran Member
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
I have three large brush piles that I would like to burn next week. I used the TC 55 to loosen up the snow and ice covered wood so the fire would get more air. About 100 feet out of the garage the engine stumbled to a halt after a half hour of warming up. I removed the fuel filter which was coated with ice. The tank was dry when I received the tractor. I refilled it with blended fuel and anti gel treatment. Lucky the spare filter was in stock and ten minutes later I was in business. It sure seems alot colder than the weatherman indicates.
   / Found out about fuel filters today #2
You need to be careful with todays new high sulfer diesel fuels. If you are filling your tractor from a can that was filled at a gas station, you are probably getting the new blend. This blend requires different additives then used to work to make them anti-gel. K100 is a good additive that covers most of your needs. Just thought I would mention it if you continue to have problems with the fuel.
   / Found out about fuel filters today #3
Larry_NFES - It doesn't sound like he had a gel problem but a ice problem, two different problems. If he actually had "ice" in his filter then his tank had water in it and had nothing to do with what type of fuel was in the tank. If he doesn't keep the tank full it could have come from condensation. And the new fuel is "low" suflur, not "high" sulfur.
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2015 FREIGHTLINER...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
