Found my hydraulic leak
   / Found my hydraulic leak #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
I have had a bit of a leak for a month or two. I took it in and the rear gasket was replaced. We all thought that was the fix. Got it back and no change. Took it back for another look. They looked a little closer and they think they have found the problem. I have a cracked transmission housing. I have racked my brain for anything that might have caused it, but I don't remember any event that might have caused it. I guess parts just break sometimes. I was under it last week and was thinking how clean it looked underneath. The paint still looks new on everything but the drain plug. I guess sometimes things just happen. The dealership has been strong so far. They let me know what was up within 2 days what was up(had several units in front mine). I am not happy that it needs repair, but I can't complain about the dealer.
   / Found my hydraulic leak #2
Messmaker,will it be a warranty repair?If you didn,t hit something it must be a bad casting.Hope so,could get spendy if it,s otta your pocket:(Dave
Not a grumble from dealer so far.He did not mention abuse.I have about 10 months left on my warranty. I am not sure how I could crack the casting if I tried. About 85% of my work is with a brush mower. I have cut a few concrete blocks with the mower, but have never hit anything with the tractor. I run it with the loader low, so it usually clears the path.
   / Found my hydraulic leak #4
Messmaker, at least you found it before the warrenty was expired
:thumbsup:
9 working days now, parts are in and it should be ready very soon. The tech told me that it might take a while, since it's the first one he's done(oh boy).
   / Found my hydraulic leak #7
Good luck!
Got it back. All is well so far. The power seems down a bit. I may need to give it a bit to get back to normal.
M & M 5 Bottom Plow (A50515)
M & M 5 Bottom...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A52141)
2020 VOLVO...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 66"...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
