Found my hydraulic leak
/ Found my hydraulic leak #1
MESSMAKER
Bluegrass,KY
DK4710SE
I have had a bit of a leak for a month or two. I took it in and the rear gasket was replaced. We all thought that was the fix. Got it back and no change. Took it back for another look. They looked a little closer and they think they have found the problem. I have a cracked transmission housing. I have racked my brain for anything that might have caused it, but I don't remember any event that might have caused it. I guess parts just break sometimes. I was under it last week and was thinking how clean it looked underneath. The paint still looks new on everything but the drain plug. I guess sometimes things just happen. The dealership has been strong so far. They let me know what was up within 2 days what was up(had several units in front mine). I am not happy that it needs repair, but I can't complain about the dealer.
/ Found my hydraulic leak #2
Messmaker,will it be a warranty repair?If you didn,t hit something it must be a bad casting.Hope so,could get spendy if it,s otta your pocket:(Dave
Not a grumble from dealer so far.He did not mention abuse.I have about 10 months left on my warranty. I am not sure how I could crack the casting if I tried. About 85% of my work is with a brush mower. I have cut a few concrete blocks with the mower, but have never hit anything with the tractor. I run it with the loader low, so it usually clears the path.
/ Found my hydraulic leak #4
Messmaker, at least you found it before the warrenty was expired
:thumbsup:
9 working days now, parts are in and it should be ready very soon. The tech told me that it might take a while, since it's the first one he's done(oh boy).
/ Found my hydraulic leak #7
Good luck!
Got it back. All is well so far. The power seems down a bit. I may need to give it a bit to get back to normal.
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
Aproximately 72' of Steel Catwalk (A62679)
Aproximately 72'...
213098 (A64276)
213098 (A64276)
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
Caterpillar 318BL Excavator (A65579)
Caterpillar 318BL...
