Found me a dk55, looks like good mach.
/ Found me a dk55, looks like good mach. #1
gunner
I found me a used dk55 today w/200 hrs on it the price is prety good I don't know if I want to go this route or not I see afew compliants about this mach.It has a rhino loader not sure of the size or model it has 13 months of warrenty left on it though .
Just looking for some advice thanks for any help that I can get.
Gunner
/ Found me a dk55, looks like good mach. #2
Welcome to TBN Gunner.
My first question would be: What complaints have you seen about this machine? I've seen almost none, but I have an open mind. If you know of any brand that hasn't had some complaints, I'd like to know about that too.
The DK55 is an excellent tractor with lots of good features. Is this a cab model? The only thing about the cabs that is being corrected, is the way the AC works, sometimes fogging up the interior, but not a big problem.
I certainly wouldn't let a few complaints about a model stop me unless that tractor is experiencing the same problems, and then I might still go for it if I know what needs to be done to correct it. Otherwise, you couldn't buy most anything!
You would love the DK55, it's a good strong tractor that will work like crazy. John
KiotiJohn
the only complants about this model of tractor that I have seen were about the loader .the 55 that i've been looking at isnt a cab model ,it is one heck of a good looking machine,big ,stout and powerful /forums/images/graemlins/smile.gifBut the kioti dealer told me today that they [kioti ] cuoldnt finance a used tractor that even had 200 hrs on it /forums/images/graemlins/frown.gif so im back to looking at the dk45. my cousin sells alot of used tractors ford and john deere [big tracktors 65-110hp] he found me a kioti dealer today that he sells implements to, this dealer qouted me a new dk45 w/agri tires and a koyker loader for around 18500 Im supposed to talk to the dealer tomorrow.
gunner
/ Found me a dk55, looks like good mach. #4
</font><font color="blue" class="small">( But the kioti dealer told me today that they [kioti ] cuoldnt finance a used tractor that even had 200 hrs on it so im back to looking at the dk45. my cousin sells alot of used tractors ford and john deere [big tracktors 65-110hp] he found me a kioti dealer today that he sells implements to, this dealer qouted me a new dk45 w/agri tires and a koyker loader for around 18500 Im supposed to talk to the dealer tomorrow.
)</font>
The financing is done by Agricredit Acceptance LLC, not Kioti, but in a deal with Kioti. I feel sure that Agricredit does used financing, but I'm going to check with someone tomorrow and let you know.
There have been some complaints about the rollback on some of the loaders, but some posters have said they didn't find it to be a problem. I guess it depends on what one is doing with the loader. I'm not so sure that's a good price for the DK45 with that cheaper Koyker loader on it. I'd much prefer a Woods loader or one of the other major brands over the Koyker for that tractor for that amount. Tomorrow I'll find out some things for you, and send you a private message. John
/ Found me a dk55, looks like good mach. #5
KiotiJohn you are correct about the financing, they (Agricredit) will finance the used but at their standard rate.
/ Found me a dk55, looks like good mach. #6
</font><font color="blue" class="small">( KiotiJohn you are correct about the financing, they (Agricredit) will finance the used but at their standard rate. )</font>
Thanks Jon. That's the same thing I found out today. John
Thanks guys I think that i've got the finacing thing nipped in the rear /forums/images/graemlins/grin.gif I'm just not sure which route to take now though .
One dealer gave me a list of 45 owners to call and check out to see if they were pleased with their 45s I dont know of any one who has a 55 but I'll ask today I did here somewhere that the front axles werent heavy enough on the 55s, that they would break sometmes under weight of the loader .THIS would be a BIG concern to me because I will be using this tractor and loader almost every day and i'll be using the fel a bunch .
gunner
/ Found me a dk55, looks like good mach. #8
I have never seen or heard of any problems on the front axles of the DK55. I have one customer who uses his around his landfill and does alot of loader work and never a single problem. The 55 is a really nice machine. We always keep several in stock as they are pretty popular models.
/ Found me a dk55, looks like good mach. #9
I have seen one DK55 axle problem at my dealer's. The guy who owns it is **** on equipment from what I can gather, but he broke the bevel gear on one side. I saw the gear, cast, which I think needs to be improved, as I feel the gear and pinion is a little small. According to my sources, this was once a problem on the DK45s but they made changes. It is a very rare occurrence with either tractor made in the last couple of years, and was never supposedly common to the DK55. John
/ Found me a dk55, looks like good mach. #10
In general, rear counterweight is so important. Without it, you basically are tetter-tottering all the weight that's in the FEL bucket over the front axle.
On the Kioti website, for the DK55 FEL, it states they use 1,200 Lbs. rear ballast/counterweight.
Don
So what do they figure someone should use to get in the nieghbor hood of 1200lbs.That would be an awful big box blade /forums/images/graemlins/grin.gifI'm having my tires loaded on what ever I get ,it helps for pulling traction and the rear tires should help to keep the weight more balanced that way.
/ Found me a dk55, looks like good mach. #12
</font><font color="blue" class="small">( So what do they figure someone should use to get in the nieghbor hood of 1200lbs.That would be an awful big box blade )</font>
LOL, sure would be. Of course the 1200# is to get the very maximum lift out of the loader, but I don't know what you'd put on the back. The largest backhoe available for the DK55 weighs 980# without the bucket. So I guess, with the bucket, there would be enough weight for maximum, but probably not since there's a subframe involved that spreads the weight. I don't know. John
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
2014 Freightliner 105' Bucket Truck (A61306)
2014 Freightliner...
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
