Found a great gas can spout!!
   / Found a great gas can spout!! #41
I watch the old WWll documentaries on TV. If you look real close on some of the old footage - you will see the Germans were using Wavian Jerry cans back then.
That's the brand I would buy if I didn't already have my four USA Jerry cans.
I'm not arguing they're not great cans and probably the top of the line metal cans. But man for the price I could buy a new plastic can every few years for the rest of my life and probably come out ahead.
   / Found a great gas can spout!! #43
Yes - the Wavian cans ARE expensive. I got my cans for free from a military friend. They still are painted OD. Some really good paint.
   / Found a great gas can spout!! #44
I quit "pouring" gas/diesel into my trucks/tractors long ago...
I still use cans, but I use the pumps sold on Amazon that take 2 D cells, and let them do the work. I have one for gas and another for diesel.
They even shut off when the tank is full, so NO spilling and NO funnel needed either. Plus the batteries last a LONG time.
SR
Sawyer, I have been lifting the 5 gallon cans to fuel the tractor - not a favorite task. So, I am interested in the pump idea. My tractor's diesel tank - like most I assume - is at least 5 feet above ground level and the hose would have to be even higher to make the turn into the tank. However, comments on Amazon mentioned the pumps do not work unless the gas can is basically level with the tank you are filling. That makes no sense.
Anyway, I am about to pull the trigger on one of the battery powered pumps but thought I would check with you - I am assuming there is no issue pumping from a can on the ground into a 5 foot high tank?
   / Found a great gas can spout!! #45
The small pumps that I have, will not pump 5' up, for small amounts of fuel for smaller tractors/generators/ATV's I just buy fuel in cans and put them near level, and let the pump do the rest.
Lifting the can isn't the problem for me, it's pouring with it, so the pumps work great for me.
For tractors that use a lot of fuel, I have a 12V fuel pump that's used in a fuel tank.
SR
   / Found a great gas can spout!! #46
SR
Thanks. You have saved me from making a mistake. I will check on other options.
   / Found a great gas can spout!! #47
@beowulf
Look at this, even more money then the no Spill, (kind of ridiculous to be honest), but mine is setup the same way, but i knew i would never be able to hold it, i rest this on the steering wheel, and it just takes some hand pressure to hold the lever down, but you don't hold the weight of the can at all, drains pretty quick as well, need to tilt a little at the end, but the can is pretty much empty at this point
   / Found a great gas can spout!! #49
It is great to see all these great tips on refueling!
I am still lifting my Wavian cans, so for the moment I am ok. With any sort of shoulder injury, that would be gone in a flash.
I have only had my Wavian diesel and gas cans for a little over a decade. They still look and act brand new. I replaced the o-rings ("D" rings?) on the gas can a year ago. Something in the fuel caused the originals to start cracking. The diesel cans are fine.
I love that they are leakproof. As in totally leak proof. I can fill up the Wavian tanks at the gas station and drive them home in the car over a very twisty, winding road, and not a whiff of fuel leakage. The same was never true of the plastic Jerry cans, even the no-spill cans, in part because there is 2000' of elevation gain, which tended to force fuel out of the plastic cans as the fuel sloshed around in the cans on corners. I routinely open the Wavian fuel cans a month or three later, and they are still under pressure from the altitude change. I no longer have any trouble with gasoline going bad. For me, those reasons make the Wavians worth every penny. I just used 5 gallons of pre-Covid gasoline with no issues. (I don't use much gasoline on the ranch, and storage is one of my issues.)
I have a couple of the No-Spill plastic cans still that I reserve for refueling things with small fuel tanks, like my gasoline generator, and for 2-cycle mix. I like them for small refills. The minor problem for me is that, here, I am always fighting temperature changes that swell and buckle the cans. I quit using the larger 5 gallon can as fueling anything with it was just too sloooow.
I used to have one of the US military style Jerry cans and then misplaced the spout. For years. After more than a couple of years, I gave it to a friend who had several, and about seven years later, I found the spout and gave it to him, too. Unlike @oosik's mine had a cork seal, and it was less than leak free. Even the metal spout had a tendency to weep fuel. If it was a knock-off, it was an old knock-off. It came with the property.
Personally, I think that the Wavian design works better it a couple of ways; the three bar handle makes it easy to carry two empties in one hand, or one full can, and the cam-lock lids and spouts seal tightly without tools.
Yes, they are way more expensive, and I bought mine on sale for more than half off, but they solved a couple of issues for me (leaking fuel, and bad gasoline). For me using them is like using any well designed tool, a pleasure.
And no, I am not wild about the CARB compatible spill resistant nozzles. (But I do spill less with them.)
All the best,
Peter
   / Found a great gas can spout!! #50
@beowulf
Wow! I have a couple of the Red ones for gasoline for the ATV's and mowers, but I bought from Lowe's a few years ago and thought the $30 price was high!
My biggest complaint about them is the filler neck on mine is at the 45 degrees and it will just barely allow you to pump in 5 gallons.
Look at the different pictures, some are at 45 some are on top, I would only want one with the filler opening on top knowing what I know now.
2019 TRAIL KING INDUSTRIES ADVANTAGE PLUS TRIAXLE RGN W/FLIP AXLE (A55745)
2019 TRAIL KING...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A54865)
2005 Volvo VNL...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
2012 EZ-GO Cart (A55853)
2012 EZ-GO Cart...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
