found a 7" x 16' steel pipe here at work
   / found a 7" x 16' steel pipe here at work #11
Re: found a 7\" x 16\' steel pipe here at work
Chances are it's six inch pipe ( 6 5/8" o.d.) /forums/images/graemlins/confused.gif
If it is you can cut it in half. Find some JD disc separators. Weld these on top for caps. They take the plain old pipe from ugly to beautiful lamp posts. The separators have an urn look that makes a perfect lamp post when put on to of the pipe.
A sixteen footer would make a nice hinge post for a five hundred pound gate if it isn't over twenty foot long and you can go down ten or eleven feet deep with concrete.
If it's plasma cut lengthwise into quarters you have perfect corners for say a truck bed. That's how I made Lucy's bed corners. Everyone assumes I have a killer brake. Nope, just a plasma and more than a bushel basket of patience.
   / found a 7" x 16' steel pipe here at work #12
Perfect for a windmill post. /forums/images/graemlins/smile.gif
   / found a 7" x 16' steel pipe here at work #13
STICK it the middle of your front yard, and let the neighbors go crazy figuring out what it is for /forums/images/graemlins/grin.gif or better yet give it to WROUGHTEN HARVE he most certainly can figure out what to do with it. the man is a genius with pipe!
   / found a 7" x 16' steel pipe here at work #14
Weld a 4-inch half circle 1/2-inch thick steel plate longitudinally and perpendicular to the radius near "the muzzle" end and paint the whole thing black. Then have 1/2 of it sticking out from some trees pointing at the road or the driveway. It'll keep salespeople and Jehovah's Witnesses away, maybe even "Trick -or- Treaters".
Kevin
   / found a 7" x 16' steel pipe here at work #15
Now if we could only find some 7" potatos! wowzers!!!!
   / found a 7" x 16' steel pipe here at work #16
Chucko, with my 7"pipe I made a roller to press small seeds into the ground. Golf cart tires fit it well. See attachment.
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A58017)
2002 WESTERN STAR...
2009 INTERNATIONAL 9200I TANDEM AXLE WRECKER (A58018)
2009 INTERNATIONAL...
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2017 Ford (A55973)
2017 Ford (A55973)
