Foton404 safety valve
/ Foton404 safety valve #1
K Lodge
Vanderhoof BC Canada
Foton404
Looking for the safety relief valve on my Foton 404. The engine is a SL3105. Blew the seal on the pump last fall. thinking it just happened again. Wondering if the relief valve has failed. Not sure where it is located. Havent had any attachments off of it or anything. Heard a bit of a squawk from the pump side of the engine. I shut it down and checked the oil and the crank case is overfull. Same thing happened in the fall when the original pump failed.
/ Foton404 safety valve #2
Relief should the first item in line from the pump outlet. It could be a body mounted to the transmission housing or in a directional control valve..
Follow the outlet line and you should find the relief.
PALLET OF ATV TIRES & RIMS (A63745)
PALLET OF ATV...
3PT DIRT SCOOP (A63745)
3PT DIRT SCOOP...
JOHN DEERE 6R CORN HEAD (A63745)
JOHN DEERE 6R CORN...
1000 GALLON FUEL TANK (A63745)
1000 GALLON FUEL...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
