Foton FT404 oil filter housing change
   / Foton FT404 oil filter housing change #1
philtyler
S.W. Western Australia
Foton 404
The original oil filter was a JX0707 filter or similar with the 24 x 2mm thread and a seal diameter of 72mm. I originally made up an adapter so that I could fit the Ryco Z9 or Sakura C-1121 which have the ¾-16 UNF thread, which is an easily obtainable filter here in Oz. The Z9 has an outer seal diameter of 71mm and is a similar physical size. The Ryco filter costing AU$10 at my local auto parts store. Whenever I changed the oil filter my adaptor would come out of the housing, and I would have to use grips to get it out of the old filter. Annoying
Recently I saw a filter housing for sale with a ¾-16 UNF thread mounting and the same 55mm mounting bolt spacing. Its pictures showed it looked almost identical to the Foton unit as regards the oil passages. I decided to try one out. It was advertised as a KK385 3T30 oil filter housing for a Laidong tractor by CIRCLE D in Perth, Western Australia.
When it arrived, I confirmed that the oil passages and general dimensions of the Foton and Laidong housings were near identical. The only difference being that the Laidong unit had a threaded hole in the top. I am guessing it is for an oil pressure sender. I don’t need it, so I inserted a bolt with thread tape to blank it off ensuring that the bolt didn’t protrude into the output gallery.
After fitting it I fired up the engine. The oil pressure light went out and after a while the filter warmed up with the oil flowing through it. Job done. I have included a couple of photographs showing the filter housings and the completed job.
As an aside I am also using the Jackmaster engine oil bypass filter which I fitted some years ago.
May I finally add that I have also mentioned CIRCLE D in my past posts, but I am not associated with them in any way. I am just a customer.
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
Kubota LA525 Front Loader Tractor Arm Attachment (A55851)
Kubota LA525 Front...
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54757)
(2) LITHONIA...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
Honda EM3500S Generator (A55851)
Honda EM3500S...
2015 Ford F-350 Service Truck (A55852)
2015 Ford F-350...
