Foton 404 looses ground speed
   / Foton 404 looses ground speed #11
Rick,
If you can give any tips on how you adjusted your clutch, I'd sure appreciate it. Daughter's Foton engages at the very top of the pedal travel and has virtually no power whatsoever. It barely moves at crawl speed.
Thanks
Acky (Frank)
Frank, I have unfortunately gotten way to busy to break into the clutch as of yet, or remove the loader to access the inspection plate. However I did notice I had no free play on my clutch pedal. I simply adjusted the link to give about a half inch of pedal travel. This seems to have halted the clutch engagement points movement from continuing further out. With that said I dont think I fixed anything just stopped the wearing of the plate so fast from here on out. I think this may be what started the decline in your daughters tractor's clutch peformance as well. If I look back on my use and subsequent learning to use the tractor, I did an enormous amount of loader work in the beginning. I am pretty sure I left my foot on the clutch pedal for a quicker reaction should I have gotten into trouble.. similar to how one might drive a car. With the lack of free play I think it was wearing the clutch prematurely. I have since stopped leaving my foot there and do think I can eek out a little more time on the clutch as I am not completely to the top on on engagement but a replacement is coming I have no doubt. I would try to adjust the pedal link for proper end play and see if that helps but I suspect the clutch may be a goner if you can barely get it to move. with that being said. I have a few questions..
Is it barely moving in low gear as in no speed with abnormally high RPM? Or proper RPM? I bet I cant get more that 2-3 mph out of mine in low gear (low-1) at 2k RPM. But if I put it against an immovable object I can churn all 4 tires at any RPM this has ensured me I do not have a clutch problem and am not slipping yet. I usually putz around in low-3 unless am I am using the loader and then I am in low-1with no speed but plenty of power.
Second is it possible the brakes are hung? My left brake hangs sometimes and it does take a lot of power to move it until I figure it out .. usuall figure it out because I am counter steering to go straight, and it just feels funny. I put it in reverse for a second and the brake breaks free and I can continue again. If both are hanging you would have a very severe loss of power but I suspect you might know its happening I just wanted to throw that one out there in case your RPM not really high or you can prove or not the clutch is slipping. If you have a loader do a stump or tree test for slipping.
   / Foton 404 looses ground speed #12
Rick,
Thanks so much for your suggestions. When I get to my daughters house next weekend, the first thing I'll do is look at pedal free play. If it's an issue, I'll do an adjustment. You're right, it's not a permanent fix, but it's below freezing up here and these old bones just don't take to the cold like they used to. Hopefully, it will last till the warmer weather gets here.
The tractor barely moves no matter what RPM. I'll also check and see if a brake(s) might be hanging.
I'm sure I can find a stump or tree somewhere on her property to test for clutch slippage, provided the tractor can make it there.
Why do these issues always raise their ugly heads in the middle of winter??? Although I am somewhat mechanically inclined, the thought of having to split a tractor to get to the clutch is almost beyond my belief system. That's certainly a summer project.
Once again, many thanks for your invaluable input. Have a safe and prosperous New Year.
Acky (Frank)
   / Foton 404 looses ground speed #13
Something else to check is the bolts on the bell housing some times can come loose causing these types of issues. if not caught when first loose there can be major issues,. it is easy check to go over all the visible bolts and tighten them.
If not a free play adjustment in the clutch clevis under the floor board then maybe look for other broken parts. how many hours on it again>?
Mine (JINMA 284) broke a clutch (cone style) spring I think as it was a sudden change & mine has been a issue for 3 years & just no time to split it & fix it. I have treated mine as a bulldozer 90% of the hours on it.
Mark
   / Foton 404 looses ground speed #14
Adjusted the pedal free play and that seems to have done the trick. Tractor is performing OK. Many thanks to all for your great suggestions and help with this issue.
The warm weather can't come fast enough for me. Happy New Year to all.
Acky (Frank)
   / Foton 404 looses ground speed #15
Glad you got it fixed Frank and that it was an easy one. I still think my clutch engages and releases a little high so maybe next year I will tear it down and rebuild.. Of course with a full detail of my screw ups and pictures :)
Deere 9965 Cotton Picker (A51039)
Deere 9965 Cotton...
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A51039)
2019 Energreen EVO...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
