Buying Advice Foton 404 Belt Lengths
   / Foton 404 Belt Lengths #1
Bareen
Tractor King 404
Does anyone know what the generator and fan belts lengths are for a Foton 404 tractor? I don't know the engine model number, but I think it is SL3105. I have the Engine Parts book, and it lists the fan belt part number as GB1171-74, the part Name as Fan Belt B1118 or Fan Belt B1168. The parts book I have does not list a generator belt length. Sorry if this is the wrong place to ask, it is my first post here. I inherited the tractor years ago and want to replace the belts.
   / Foton 404 Belt Lengths #5
My post seemed to have disappeared which is fine because I had to edit it anyway. Had the fan belt blow and decided to change the generator belt at the same time. The generator was a 5/8 28" belt. I had to take the coolant plate off the manifold in order to get the belt off so be aware changing the belts means you need to have some deisel coolant handy.
The fan belt turns out to be a 36" 5/8's. Had some difficulty sizing it because the old one was tore up pretty bad. I had to fight it on so it is possible this is supposed to be a slightly longer metric belt or a 36.5 but a 37 was definitely too big. My tractor engine number appears to be S 3105ABT-1. It's a 2007 Foton 404. Hope this help's someone. :)
In order to get the fan belt on we put it over the top pulley and part way around the lower pulley from the left hand side. I then turned the tractor over about 3 times for the engine to turn the pulley over and drag the belt on. I then used a pry bar, the flat side, so push the belt towards the right side and over the tensioning pulley. It needed very little tensioning once it was on.
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2015 Ford F-350 4x4 Knapheide Service Truck (A48081)
2015 Ford F-350...
2021 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A48081)
2021 Ram 1500...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Shoreline Boat Trailer (A50860)
Shoreline Boat...
