foton 254 to much lights melted fuse box
   / foton 254 to much lights melted fuse box #1
domains
Hi... The fuse box has 4 fuses
My question... I bought a universal fuse box, that has a bolt( for all live wires)? and only one wire needed to plug in per fuse.
In all there is 7 wires, the big red wire goes on ground bolt?
all live wires go on the bolt? the other wires on fuse?
   / foton 254 to much lights melted fuse box #2
Is that a mounting bolt or a bus bar bolt? Picture please.
   / foton 254 to much lights melted fuse box #3
You don't ground DC fuse boxes, but without a photo you won't get an accurate answer. The bolt could be for mounting, or it could be for a common 12v supply
//greg//
//greg//
Got a friend to wire it, 3 fuses ran on one small wire causing heat, so all rewired bigger wire grade.
sorry had no camera to take a pic
   / foton 254 to much lights melted fuse box #5
Ok. And if you add additional lighting, it should either be run off a relay - or be separately fused.
//greg/
   / foton 254 to much lights melted fuse box #6
The BOLT on the fuse box should be the MAIN HOT WIRE coming into it. It should be 10AWG or bigger for 30 amps. The fuses all have a bus that connects one side to the bolt the other side of the fuses are the wires that are protected by the fuses (one wire out.) Greg was correct the lights should have a RELAY (from the light switch power lights on turn ON the relay) the Relay turns ON the lights. 2 ea. 55 watt lights on 12 V should have a 15 amp fuse and 14 awg wiring
Mark
Mark
YES.. the bolt was the main red wire (30 amp fuse), not sure of wattage of bulbs but with size of wires installed the guy said i should not have any more issues.
weird part was the big red wire was plugged inline with a small green wire. maybe red wire is not cheap in china :)
he placed 2 fuses separate alone on a fuse, not sure if i have relays
2006 foton
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
Maletti K2700 3pt 7' Tiller (A50121)
Maletti K2700 3pt...
2018 Bobcat T590 (A50120)
2018 Bobcat T590...
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
Chery 6' 10 Drawer Workbench (A50121)
Chery 6' 10 Drawer...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
