Foton 254: How to take measurement of clutch fingers
   / Foton 254: How to take measurement of clutch fingers
The pressure plate "levers" are the "fingers", that the release bearing push against to release pressure on the clutch. I believe we are talking about the same thing.
   / Foton 254: How to take measurement of clutch fingers #12
I agree with your statement the only thing I find weird is why the service manual says do it as I mentioned above.
If you have the tractor apart, it's easier to get all the fingers the same while it's apart and then set the clearance once it's back together. If the tractor is together and the fingers aren't the same it's easier to adjust the fingers individually in place than to split the tractor. Once the fingers are all at the same clearance you shouldn't ever have to change them, you can make up for clutch disc wear by adjusting the clutch pedal linkage.
Jinmas are notorious for not being adjusted during assembly at the factory, and arriving here with the fingers at different clearances. Good dealers will adjust the fingers as part of the final assembly. Since you can't be sure that the adjustment has been properly done until you do it, the emphasis is on checking the individual clearances.
ok thx I will definitely check the fingers before I put the cab back on :)
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
2005 Mercedes-Benz C-Class Sedan (A50324)
2005 Mercedes-Benz...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
