Bob Rooks
Elite Member
I'm sure you meant hydraulic pump seal....but a damaged injection pump seal can permit hydraulic fluid to flow from the pump through the drive gear housing and into the engine crankcase.
//greg//
//greg//
Nope, but I did make a mental error typing. Too late to edit out the original mistake. It should have said "a damaged injection pump seal can permit diesel fuel to flow from the pump through the gear housing and into the engine crankcase." That said, the same thing applies to engine driven (as opposed to PTO driven) hydraulic pumps. A damaged hydraulic pump seal can permit hydraulic fluid to flow from the pump through the gear housing and into the engine crankcase as well.I'm sure you meant hydraulic pump seal.![]()
Bob
Yep, that was one type. The one I recall was only 2 tubes, one for the sample, and one for the control, came in a long wooden box.
EDIT: OK, here is the model I was used to, made by Visguage.
Oil Viscosity Testing Comparator - Visgage Portable Oil Viscosity Tester
I didn't realize you were a Coastie also? What ship were you refering to? I did a tour on Acushnet, she had 4 Opposed Fairbanks Morses. Was also an underway EOW on Polar SEA. That was where we had Alpa Laval lube oil, Fuel oil and hydraulic oil purifiers... The FOP's were the largest I have ever seen as when on the birds we used a whole lot of the stuff(4500GPH)... Probably the coolest job I will ever have as where else do you get a chance to crack the throttles on 75,000 shaft HP![]()
