Forward reverse pedal
/ Forward reverse pedal #1
RoninNY
Hudson, NY
2005 Case IH DX33 , 1953 TO30
Has anyone had this problem. I have a 2004 Case/IH DX33. One of the major problems I have is the forward/reverse pedal does not self return back to neutral on its own. Not a good situation in tight quarters. I have looked, lubed and so far have not found where it is either binding or causing it not to return. If anyone has had this issue, I would live to hear about it. Thanks.
/ Forward reverse pedal #2
Give the dealer call might be just adjustment.
/ Forward reverse pedal #3
Forward AND reverse spring tension have lost their "springallity". After approximately 16 years of use, I'd replace them anyway.
["springallity" is so a word.]
/ Forward reverse pedal #4
I love that word!!
Hello all, and a follow up on this thread. Dug into it yesterday, and found no springs that would return the pedal back to neutral. But after searching I did find a very very hard to find zerk fitting on the HST shaft. Looks like it has never been greased in 15 years. I still think the zerk needs replacing but i was able to force enough lube to be able to free up the pedal. Works much better and glad to find the trouble. Thanks all for the input.
/ Forward reverse pedal #6
Ahhh... the old 'hidden zerk that isn't shown in the Owner Manual' trick.
I had mine (4105) shown to me by my Dealership's mechanic when I asked about a couple of grease nipples that were indicated on the front wheels axle, but I couldn't find. The Manual wasn't updated midway through production (too expensive). The pedal 'zerk' had been added, but wasn't shown.
