forks for L302 loader
/ forks for L302 loader #1
tony3542
Nashville Tn
2006 B7610hst
Where is the best place to get forks for a L302 loader,the kind you screw on.
thanks,
tony
/ forks for L302 loader #2
ATI has a pin-type quick attach for LA302 loader type. It weights only 21 lbs. With this you could easily swap between your bucket and forks. About the forks, they have a small pallet fork frame with forks for small tractors.
I'm not sure what you mean by "the one you screw on". Do you mean the one with the pins? It's clear that you're not talking of a Skid Steer type quick attach.
/ forks for L302 loader #4
Do you have welding skills or access to someone who has?
If so then I offer a FREE set of plans to build your own. You can do this for less than $50 in materials. Plans include detailed instructions and a cut list.
The package also includes plans for a clamp-on reciever hitch.
If interested, send me a PM and include your real email address. Over 300 satisfied customers have their set of plans.
/ forks for L302 loader #5
Timber said:
I think he meens the clamp on ones
You're right Timber... I feel a bit stupid. :eek: It happens. Sorry wrong information
/ forks for L302 loader #6
I had a set of king cutter clamp on forks for my 302 fel. They are rated for 2000 lbs and work well.
Thanks for all the info.Thanks Mad I'II take you up on those plans,I don't weld I'II check a local welder with the plands a see what I can do.I really need some of these forks.
tony
/ forks for L302 loader #8
These are the ones I have, They were not cheep but they were the ones I wanted for what I do. I do a lot of fork work. Being around forklifts all the time it is just a way of thinking
/ forks for L302 loader #9
Just a matter of caution. When building the forks make provisions for a vertical stop that prevents a log or some such thing rolling back and sitting in your seat. This can happen at full height and fully curled back bucket.
Don't ask on how I know this.:D
/ forks for L302 loader #10
I have the exact same forks timber, manufactured by king cutter.
/ forks for L302 loader #11
I'm in the same boat. In facts, I use my forks more than my bucket.
/ forks for L302 loader #12
The 302 fel is under rated, we planted big trees with those forks, weight well in excess of kubota's specks!
Thanks Mad for the plans,I'II have check on the price of material.couldn't beat the price either.
Timber ,those are someheavy duty looking forks.I see where Northern Tool has some 8000lb.rated for $249.00,they'd probably do for me,the sign doesn't weigh a1000lb or so.
thanks all,
tony58
correction.....ment to say 800lb and 100lb.
thanks
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
iDrive TDS-2010H...
L6060 Kubota For Sale
2014 DODGE 5500 SERVICE TRUCK (A65643)
2014 DODGE 5500...
2012 EXAOS 130BBL (A65643)
2012 EXAOS 130BBL...
