Forks for FEL
   / Forks for FEL #1
ACHINBAC
Middleborough, Ma
BX24
Hanging out to dry - finally finished the forks for the bx24. They also provide a base for the carrier I'm planning to work on today. If you check the pic of the fel, you'll see why I had to pad the forks - it accomodates the additional thickness of the 1/2 x 4" cutting edge. Also welded a web on the back to stiffen them a bit.
   / Forks for FEL #2
Are you planning to mount them to the bottom of the bucket ?
   / Forks for FEL
They hang off the lip of the bucket and one bolt holds their tails to the bottom of the bucket. The pic of the fel is old and doesn't have the two holes drilled in it yet. The bucket edge is pretty stiff now with the additional cutting edge though I can install the strut from the fel hitch assembly to stiffen it further if the forks loaded flex the bucket edge. I tried standing on the tip of one before they were painted and got minimal flex (175#) and don't expect the hydraulics to handle much more.
   / Forks for FEL #4
Very nice!
I hadn't thought of using channel with a partial web for forks. I was always thinking used commercial forks, heavy flatbar, or rectangular tube. Great idea, thanks.
   / Forks for FEL
No laughs here all you big tractor guys - this is a toy for me, otherwise I wouldn't have dialed it in. Some pics of the finished forks, and the carrier to follow on the next post.
   / Forks for FEL
Carrier is 3/4" marine ply with glass fabric layed on the top & epoxy + milled glass to seal the bottom. Bucket brackets are 2x2 stainless scrap angle cut to shape. Bottom has 2 strips of EPDM rubber registered to the forks.
   / Forks for FEL
Top has 3M skid tape strips applied. First load was (today) components for a wine cellar to be installed in Chatham.
   / Forks for FEL #9
That is nice very work.:D:D:D
The cutting edge must really stiffen up your bucket?:D
I too have bolt on Forks on the Kubota B7100 but they are much shorter and made from cut down truck springs. For a carrier the forks get a wooden pallet placed on them. Mine surely do look as nice!:(:(
   / Forks for FEL #10
Nice work. I also really like what you did for lift hooks/rings on your bucket. I think you just sold me on that approach!
Steve
2016 John Deere 6155M (A50120)
2016 John Deere...
2008 Ford F-250 (A52748)
2008 Ford F-250...
Deere 302K (A50120)
Deere 302K (A50120)
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
