Forklift stuck in forward geat
   / Forklift stuck in forward geat #1
Marvin Walker
I have a 586E case forklift that is stuck in forward gear and when in neutral still goes forward and when put in reverse locks up. This machine has been is storage for about 3 years.
   / Forklift stuck in forward geat #2
Kinda makes you wonder why it was in storage in the first place. :) Sounds like the forward clutch pack is on all the time or damaged.
The machine had a rod out the block. I had a B4 engine,
   / Forklift stuck in forward geat #4
Marvin,
My first thought was, IF the transmission was okay when the machine went into storage, you may to remove and clean the transmission control valve. It's not too complicated to remove it, just take care when disassembling it that all the little springs and spools don't get lost.
If that doesn't correct your problem, the forward clutch pack may have welded together.
That means a removal of the shuttle and a rebuild.
Here's a diagram to help you.
Mark
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
CANOE (A56859)
CANOE (A56859)
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
