Forgot to turn tractor off!
   / Forgot to turn tractor off! #1
CtRick
Connecticut
New Holland TC33DA
After spending a few hours on my machine today spreading stone I parked it in the barn to let it cool down for a few minutes. To make a long story short, I took that time to do some touch-up raking, then I rushed off to work without shutting it off /forums/images/graemlins/blush.gif. It was at low idle for about 9 hours in 50 degree heat. How bad is this for the tractor? It was still running when I came back from work. Oh the terrible shame, I don't deserve her... /forums/images/graemlins/crazy.gif
Rick
   / Forgot to turn tractor off! #2
Not to worry. You'll have a funny story to tell.
Years ago, we farmed with a propane tractor that was a bear to start. Many times at night, we'd top off the tank, point it into the wind, and let it idle all night.
Ron
   / Forgot to turn tractor off! #3
Im assuming it was diesel, it will be fine. Just imagine all of the diesel generators that run constantly and never get harmed. Diesels are made for that.
   / Forgot to turn tractor off! #4
You did no harm whatsoever to your tractor.
   / Forgot to turn tractor off! #5
No harm, but I'm curious how much fuel you used? I've always wondered how much diesel is burned idling, but you've conducted the ideal experiment!
   / Forgot to turn tractor off! #6
Besides having; A story to tell, a fuel consumption experiment, a slow charge to the battery, etc....
You could look on the bright side, and just think of it as "Fumigating" the barn for Bugs!
Lloyd
   / Forgot to turn tractor off! #7
At least you didn't run out of fuel. That would have been a major headache from what I hear. I'd concur that you did no harm to da tractor.
Moon of Ohio
   / Forgot to turn tractor off! #8
Yeah your fine. My grandfather once started his Ford (gas) pick up to get the heat going, forgot about it and it ran nearly 20 hours at idle before he took out the garbage (the next day) and heard it running. It was winter, so at least it stayed cool......was kinda surprised he admitted he did it /forums/images/graemlins/grin.gif
Anyhow, that's why I just kill mine at full throttle in the driveway and coast into the garage. /forums/images/graemlins/cool.gif
just kidding
   / Forgot to turn tractor off! #9
Rick; Chances are you probably didn't hurt it since it was that warm outside, but, it didn,t do it any good either. I know there many that will disagree with me, but here goes anyway. The diesels on most mobile equipment such as tractors, pickups, and even big trucks and heavy equiptment are really not meant to idle that long at low idle speeds. Everyone sees the diesels sitting there at what you think is normal idle speed, it likely isn't. Think of it like this, a diesel uses compression that produces heat to run. You hit it on the nose saying that you left it at low idle to cool, that is exactly what it does, now think of this, if that engine basically runs on heat for combustion, isn't it logical to assume you could carbon the engine up ? Also you produce condensation that we all know you don't want in your crankcase.
My Powerstroke even has a feature to prevent this at idling around 30 degrees and below. The time frame appears to be temp related, but it will kick the idle up to around 1000 rpm to keep the engine temp up. That is what most people don't see.
As far as diesel generator goes, yep they'll sit there for days at generating speed, but that is way above an idle. You actually cool them by going to an idle.
I hope your not one of the **** types or you'll be out there changing all your oil and filters and flushing the engine at least three times.
After all this, you probably did no real harm but like I said, you did no good either. Just don't make it a habit. It sounds like you won't.
Come on people, I know someone will disagree.
My computer, my dime.
   / Forgot to turn tractor off! #10
I have seen in very cold weather,construction equipment/coal fields leave equipment run 24/7,the train engines rarely ever shutdown. I do not know what the long term effect is,I would assume it is not harming the engines too much as long as the engines are serviced properly.
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
KUBOTA M7-132 (A53084)
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2015 Forest River Rockwood Roo 19 25FT T/A Travel Trailer (A51694)
2015 Forest River...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
