Forestry Mulcher recommends?
/ Forestry Mulcher recommends? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I was just admiring RAW's forestry mulcher and wondering if anyone has seen something along the same lines for a CUT that runs off of hydraulics and is lighter in weight. The property has 3 to 4" sapplings that the brush hog will not take out, but is too small and dense to make sense of it doing with a chain saw..
Carl
/ Forestry Mulcher recommends? #2
Carl
Carl,
All those mulchers are Industrial with a capital "I". The hydraulics are 40 - 50 - 60 - 70 gpm and they need 70 to 100 hp to operate. Even the small ones are way spendy. It's probably best to have a person with an AVS or similar come in and munch it up for you. Unless you are going into the biz....
jb ($0.02)
/ Forestry Mulcher recommends? #3
Hey! Here's what I found in all of my searching.
The mulching heads that use hydraulics just aren't suited for tractor hydraulics. But there are a couple of options for PTO mulchers.
There is Seppi (who made mine) and Loftness is about to release one for smaller tractors. The Loftness unit is a scaled-down version of the monster they run on the New Holland TV145. I believe they said it will cost roughly $30K though. Seppi makes some PTO mulchers smaller than mine too. FAE also makes a PTO mulcher.
Also, there are plenty of brush-hogs out there that will handle larger material.
In a perfect world, someone would design a mulching head that could run off of tractor hydraulics (or an added pump) and would mount to the attachment plate of a FEL. I would have made a very different purchase decision in that case.
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
20ft New Elk Design Gates (A65579)
20ft New Elk...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
Refurbished KBH Tender (A63689)
Refurbished KBH...
Lowe Quick Attach 1650 Classic Hydraulic Auger Drill & Bit (A66285)
Lowe Quick Attach...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
