Fords aluminium body
   / Fords aluminium body #41
I've heard about doors drooping over time on the aluminum bodied trucks. Guessing big 'ol farm boys using the door to climb in!
   / Fords aluminium body #44
My 2015 is coming up on 7 years now, Northeastern Minnesota where salt begins in late October and extends into April. No body rust - major advantage over the 2005 it replaced. Backed into side of bed with my RTV and body shop was able to repair without replacement. Crunched tailgate too bad to repair - normal thing here is for farm pickups to have different color tailgate than rest of the truck but mine was too new when it happened so I got a new tailgate. My major "didn't think of that ahead of time" issue has been my magnetic mount amber flashing lights I use when towing large equipment - that was get 400 miles away from home, hook up disc, slap lights on roof and oops! Ratchet strapped through doors, closed and it worked.
   / Fords aluminium body #45
I was stuck in a bad hailstorm a couple of weeks ago. My F150 was pelted with quarter sized hail and when I got home, there were no dings whatsoever!
That's good to hear. That has been my biggest fear, LOL
Honestly, I don't know if the Ford's are any different, but I made a living in aluminum cab class 8 trucks and I've never had a problem with aluminum bodies.
I do though, love the fact that this F150 is not going to have the body rotted off it in all this road salt in the next 5 years like all my past vehicles.
   / Fords aluminium body #47
Fiber beds too, in Denali and Toyota has it in the Tundra (new for 22) and Tacoma.
What is going to happen when these trucks crash and burn?
Carbon fiber becomes a serious environmental hazard when it burns!
   / Fords aluminium body #48
Fire apparatus was notorious for rusting out in the 60's and 70's so one builder started using all aluminum bodies and aerial ladders in the mid 1970s. Basically it changed the entire industry so within a few years no one used steel bodies. So, at least in that industry, aluminum bodies have been used successfully for close to 50 years now.
The early versions did have a problem with corrosion popping up under the paint, but I believe that was mostly due to poor preparation before painting. Where I worked we had a fleet of over 100 vehicles and as best I can recall none of the rigs produced from the early 80's on exhibited the paint popping and the problem of body corrosion disappeared.
They were also quite a bit lighter which made the braking on the big stuff much better. We had on group of five pumpers that were delivered with steel bodies and you basically had one good stop in them before the brakes faded. We had them re-bodied with aluminum bodies after they rusted out and braking was not issue with those rigs from then on.
   / Fords aluminium body #49
The way the salesman explained it to me was the GM body is steel but anything that attached to it with a hinge is aluminum, i.e. doors, hood, and tailgate.
   / Fords aluminium body #50
But the problem with the aluminum bodies was if the truck got hit. Get hit in the left rear, it would flex the compartment body and pop welds in the right front. We saw that especially with the ambulance bodies when they moved away from steel frames. Have a major impact and you had to pull the skin off all 4 sides to check for frame damage.
S/A Flatbed Utility Trailer (A55758)
S/A Flatbed...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A53421)
2025 Single...
2011 Chevrolet Traverse 1LT SUV (A53424)
2011 Chevrolet...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
CATERPILLAR 928F LOADER (A52707)
CATERPILLAR 928F...
