Ford8n Antifreeze
   / Ford8n Antifreeze #1
Birchhatchery
bfe
in search of new iron
i would like to drain all the antiyfreeze in my 1950 ford 8n whats the best way to do this some of the bolts are very rusty so i dont no if i want to try and pop the drain plug off i may break the bolt:confused: could i just disconnect the bottom hose and let it drain on a bucket to get it out? let me no wat the best option for me is
   / Ford8n Antifreeze #2
if you are worried the petcock is seized and don't want to mess with it.. pop the cap and then pull the lower hose off and have a trough ready... then flush with a garden hose a bit. inspect hoses.. and repalcee if needed. also the thermostat in top hose. back flush the block while at it.
fill back up with proper mix of green coolant and water to match your climate. do not fill the tank to full.. just fill it to cover the coils. fill to coils.. start up to fill engie.. then top of.. then go...
   / Ford8n Antifreeze
it has a small leak is it alright to put stop leak in the raditor on these tractors?
   / Ford8n Antifreeze #4
is it allright? um.. I guess if rain was approaching and I needed to get my crop in or my familly starved and I was gonna loose the farm.. I guess... otherwise it just sediments up the cooling system and reduces it's effectiveness.. and lets go when you least expect it leaving you worse off than before.
where's the leak?
hose = replace
water pump = rebuild or repalce.. personally I'd replace
radiator = repair or repalce ( recore / solder if possible )
block / head = post back
soundguy
   / Ford8n Antifreeze
the leak only happens when the tractor is up and really warmed up it leaks i cant really tell somewere on the radiator its on the right side corner of the front so i no its coming from the radiator somewere its a drip drip drip then when the tractor cools it stops i dont really no if it drips when the tractor is runing tho or only when it shuts off guess i should find out
   / Ford8n Antifreeze #6
very likely that stop leak would have -0- beneficial effect on a leak like that.
best to find it and fix it. use a pressure test if needed.
might be a leaking seam..
   / Ford8n Antifreeze
the leak aint bad i think i will let it go untile it gets bad anymore than i use her she can leak not and then
   / Ford8n Antifreeze #8
remember.. small elaks become big leaks.. and usually do so when you are mowign in high grass and can't see the leak.. and only find out when the engine binds to a halt.. just saying... be carefull.. i'd hate to see a 2.5 hour / 15$ repair wipe out a 2500$ tractor...
   / Ford8n Antifreeze #9
i'm sorry but there was sooooo much bad advice in that post that I have to chime in.
soldering is the time tested way to build and repair a radiator.
braze? why?
rtv? are you serious??!? it's a pressure system. rtv is not going to seal a leak liek that under pressure. ( 4psi if correct cap.. )
temps way low? only if you run a cold thermostat or none at all.
160-190 are easilly available.
jb weld might work as a temp patch depending upon the leak area.. however in practice I've found jb is a poor patch on a material that is contiously heated and cooled due to expansion and contraction making the jb let go... though it should hold for a bit if it was cleaned and prepped. but heck.. if cleaning and prepping... just SOLDER IT.
the 'no use' of a leak addative was the redeedming peice of that message...
soundguy
   / Ford8n Antifreeze
i have yet to find out if it from overfilling tho it only inch below the beck i can stick my finger in it and get antifreeze a inch on my finger
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
2024 TEXAS PRIDE 40FT GOOSENECK FLATBED TRAILER (A54607)
2024 TEXAS PRIDE...
INGERSOLL RAND INDUSTRIAL AIR COMPRESSOR (A54757)
INGERSOLL RAND...
Wright Sentar (A50120)
