Ford YT16
/ Ford YT16 #1
johnk
Elite Member
western NY
Kubota GST Grand L3130 w/ 723 loader, Ags
I picked up a used Ford lawnmower circa 1985 that is in very good condition. It comes with a PTO operated impeller for the bagger that is really great. It is pretty heavy duty compared to the thin metal sold today. Never posted on the lawnmower board so this is a first. Here are some pics..
/ Ford YT16 #2
Very nice! Those were some very good tractors in their time. They were some of the last tractors made by Gilson manufacturing, who made tractors under the Ford, Jacobsen, and Montgomery Ward names, and some models for Sears. They called the YT's "yard tractors," sort of a middle point between a lawn and garden tractor. They did come with excellent Kohler Magnum engines and heavy duty transaxles, perhaps even better stuff than what you'll find in a modern day garden tractor.
-Fordlords-
/ Ford YT16
It seems to be doing everything I need it for. I use it at my country property. Quite hilly and could use more traction. Chains will probably be next. I really like how the bagger picks up. I think if you sit in one spot it will suck the earthworms out of their holes. Oldie but goodie for my purposes....
/ Ford YT16 #4
I forgot these were made under the Bolens name too, the company at the time being called Gilson/Bolens, owned by FMC. They were sold to Troy Built/Garden Way in the mid 1990's then to MTD in 2001 where unfortunately the Bolens name is now just another one of many low end MTD products.
-Fordlords-
/ Ford YT16 #5
Hey Folks!
I have a YT16 that is in need of a steering gear/assembly. The part I need is the assembly part that goes through the body and the linkage connects to. I have searched over the net and have come up with one site (Which I can't find it now). Does anyone know anywhere in the country where I can get parts? This is probably the best tractor I have ever owned for cutting grass and I plan on keeping this machine for a long time. I can be better contacted @ sizemoreg@gmail.com. Thanks in advance for any help.
/ Ford YT16 #6
nice tractor i have the same where can i get that bagger at or who makes. i have a parts yt16 that needs patred out if you need anything, thanx
/ Ford YT16 #7
nice tractor these things are great i have the same do you know where i might find that bagger at or who makes it. i also have one of these complete for parts if ever intersted, thanx
/ Ford YT16
Not sure as to who made the bagger attachment. Possibly could be by Ford.You could try a Ford tractor dealer as they still carry parts and possibly can get a line on 1.
/ Ford YT16 #9
if you have a parts tractror do you still have the mower deck?is it in good shape?would you sell it?or do you know where I could find a good one
/ Ford YT16 #10
John, I also have a YT16 and I like it. Even tho it only has 16hp, less power than my Craftsman YS, 22hp, it will out pull it..easily!
Anyhow, if you're looking for more traction, try loading the rear tires first, then, add chains if it's not enough. My yard is a little hilly in a couple of places and after dragging a 5'x10' chain link fence with about 300lbs weight on it, (to smooth my yard), even going up those small hills, I only lost traction a few times until I loaded the rears.
By the way, if anyone is interested, there's an OEM plow for a YT18 on craigslist for $100. The guy is in the Buckeye. I tried to buy it but he wasn't interested in shipping....and I'm in Texas.
Bob
/ Ford YT16
I've had mine for quite a few years. Last week the fuel pump went and they were very hard to locate3. They said the new fuel has wreacked havoc on the older materials.
/ Ford YT16 #12
A YT16 has a fuel pump?
/ Ford YT16
Yes it does. The Kohler magnum wiith cast iron sleeves does anyways. Pricey little bugger. Jobbers around here wanted 60 to 75 dollars. Got one online new for 36 dollars to my door. They say the new gas is reaping havac on the old diaphrams,
/ Ford YT16 #14
I NEED A TRANSMISSION FOR MY YT 16. THE CLUTCH AND BRAKE PEDAL ARE ON THE LEFT SIDE. THE DISC BRAKE IS ON THE RIGHT SIDE IF YOU'RE SITTING ON MOWER.
/ Ford YT16 #15
i have had the chance to own a 75 lt16 tiwn with a briggs powerplant and love it have put typical maintenance into it
/ Ford YT16 #16
I have same tractor. The transmission is beyond repair - so I'm looking to part out the tractor. Which pieces are you specifically looking for and its quite possible I have the part you are looking for
/ Ford YT16 #17
I have same tractor. The transmission is beyond repair - so I'm looking for either a new transmission or to part out the tractor. Please let me know if you were able to find a transmission
/ Ford YT16 #18
jonnyl do you still have the parts yt16
i just bought a ford yt16 and need some parts
/ Ford YT16 #19
Just picked up a YT today and was wondering if you might have a starter you'd be interested in selling? And maybe a carburetor? Thanks, Tom
INSPECTION (A65579)
INSPECTION (A65579)
Big Star Sign (A64127)
3012SFL (A61567)
3012SFL (A61567)
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
Boom Sprayer (A64127)
