Ford TW-5
/ Ford TW-5 #1
marty
Bronze Member
Mid West
Boomer 33D
Does anyone know wether the TW-5, with front assist, rear-end hyd oil and transmission oil is all together? I know the brake fluid is seperate and most newer ford/NH have the rear and transmission together. Does anyone know where I can order a manual online?
/ Ford TW-5 #2
Try by cut and paste https://www.newholland.com/na/shopp...elid=184&catalog_id=72&prev_page=model_search
How do I enable HTML so I can make a hyperlink?
It use to be"enabled" but I don't know how it got lost or where to find it. Mark-up is enabled but bracketing the url-link in the parentheisis with url in the front and the forward slash-url at he back of the link didn't work for the above hyperlink for a TW5 manuel.RCH
RCH<P ID="edit"><FONT SIZE=-1>Edited by Rch on 11/5/00 09:22 AM.</FONT></P>
/ Ford TW-5 #4
Rch, don't use parentheses; use those square brackets [].
Bird
/ Ford TW-5 #5
Bird,I was using the squared brackets--[]-- and it would not work. I tried again just now and it still comes up " page not found ". Cutting and pasteing the same address works OK. I'd be interested if it works for you-- you can put the link in a reply,click continue to review the post and see if the link works from there. You don't actully have to send the post. Here is a test drive for me
<A HREF="http://https://www.newholland.com/na/shopping_cart/items.asp?productlineid=4&modelid=184&catalog_id=72&prev_page=model_search
" target="_new">http://https://www.newholland.com/n...elid=184&catalog_id=72&prev_page=model_search
</A> THUD!
Here is a cut and pasted version;
https://www.newholland.com/na/shopp...elid=184&catalog_id=72&prev_page=model_search You'll notice that those low dashes in the url, before "cart,id,page and search", get lost in the underling of the hyperlink perhaps corrupting the url. I'd appreciate a comment from Muhammad.
RCH<P ID="edit"><FONT SIZE=-1>Edited by Rch on 11/5/00 07:12 PM.</FONT></P>
/ Ford TW-5 #6
OK, Rch, beats me what happened. I've never had a problem with it before, but thought maybe you actually used parentheses. Anyway, I've tried it with the same luck you had.
Bird
/ Ford TW-5 #7
http://www.newholland.com/na/shopping_cart/items.asp?productlineid=4&modelid=184&catalog_id=72&prev_page=model_search
See, the thing is that the original URL you posted is a secure page (note https instead of http) so the forum didn't recognize it as a URL. I'll look into getting that changed.
What you see above is the standard secure page. It will also work.
/ Ford TW-5 #8
Bird, thanks for the extra effort. It's hard to tell sometimes if it's my mistake or something like this.
RCH
/ Ford TW-5 #9
Rch, I'm in the same situation; sometimes don't know what the problem is where computers are concerned. Maybe we both learned something from Muhammad (and not the first time I've learned something from him either)./w3tcompact/icons/smile.gif
Bird
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
2003 Coachmen Catalina Sport 220RK Class C Motorhome (A59231)
2003 Coachmen...
2015 Ford F150 (A60352)
2015 Ford F150...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2022 Horizon Trailer (A55973)
2022 Horizon...
