Ford Powermaster 801 engine seized
   / Ford Powermaster 801 engine seized #1
pwcracer
Ford Jubilee
I have what I believe to be a Ford PowerMaster 801 diesel engine swapped into a jubilee. The tractor has been sitting for ten years and the motor is stuck. I wanted to pull the injectors and soak the engine with oil, in hopes I can free it up. Would it be easier to pull the head instead of the injectors? I am having a difficult time removing them. I have a service manual on order, but it won't be here for a few days.
when I removed the injectors on my 12v cummins, they came right out.
   / Ford Powermaster 801 engine seized #2
How have you verified the motor is stuck? With the tractor sitting for 10 years the clutch could be stuck as well. If the motor is stuck, you may want to consider searching for a replacement gas engine rather than going to the expense of refurbishing the diesel engine just to tear up the Jubilee ring and pinion. The ring and pinion support in the Jubilee rear might not take the torque of the diesel engine.
1997 STOUGHTON TRAILER DRYVAN (A53843)
1997 STOUGHTON...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2013 Chevrolet Silverado 1500 Pickup Truck (A53117)
2013 Chevrolet...
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
2012 Dodge Ram 5500 (A52377)
2012 Dodge Ram...
2003 Chevrolet Silverado 2500HD Ambulance (A51692)
2003 Chevrolet...
