Ford NewHolland 3930 wiring
   / Ford NewHolland 3930 wiring #11
All that said...... I've never looked at it closely enough to swear that the relay stays continuously engaged during Start. Meaning - it might be possible that the relay briefly drops out (opens) due to voltage dropping because of the starter load ? Esp. if the battery is weak....
Coming at it from another direction..... to what extent can you verify the solenoid itself is working ? Can you measure coil resistance to check for an Open coil ? If you force 12v onto the solenoid (via fused test lead), can you confirm that it is working ? If the output fuel line is accessible, can you verify fuel flow out of the solenoid under a forced ON test condition ?
Rgds, D.
   / Ford NewHolland 3930 wiring #12
First of all, thank you for the wiring diagram! I realize this is an older post but I hope someone is still around! I just got my 3930 a few weeks ago and it was hard to start and no dashboard indicators. The wiring diagram was invaluable to troubleshoot the issue!
Thank You!
Bill
   / Ford NewHolland 3930 wiring #13
I echo the other sentiments. If you are still around, this was a big help. I have other books, but nothing showed the fuel shutoff relay.
Thanks!!!
   / Ford NewHolland 3930 wiring #14
I couldn't find the wiring diagram for my NewHolland 3930 on line. Once I got it I thought I'd share. My fuel shutoff solenoid wasn't getting any power, and I couldn't locate any info- ended up a $13 fix. Here's the diagram, info page and the supplement they came from. View attachment 279889View attachment 279890View attachment 279891
Does anyone have the supplement this came from in PDF form. The manual I have is older than this supplement and the fuel solenoid is not present.
   / Ford NewHolland 3930 wiring #15
Does anyone know how I can get full wiring diagrams for Montana green tractor 3940 HSt, probably 2005 year tractor?
   / Ford NewHolland 3930 wiring #16
dpk - also post your question in the Montana section; higher chances of response there.....
Montana
Rgds, D.
2022 CATERPILLAR 279D3 SKID STEER (A51246)
2022 CATERPILLAR...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
(2) METAL PARTS CABINETS (A51248)
(2) METAL PARTS...
UNUSED LANDHONOR LHR-PC90 HEAVY DUTY PLATE COMPACT (A51248)
UNUSED LANDHONOR...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
MILLER 330 A/BP ELECTRIC WELDER (A51248)
MILLER 330 A/BP...
