Ford New Holland 4630
   / Ford New Holland 4630 #1
lester123
I have a ford New Holland 4630, When i crank it it starts very easy, then for a second it sounds like it is going to die then picks back up and runs great
Have put new key switch, new fuel shut off solenoid, checked all wiring.
Acts like it is shuting the fuel off for a second.
Any help
thanks
Lester
   / Ford New Holland 4630 #2
Could it just be a cold weather/cold engine situation? Do you use your glow plugs before starting. Depending on temperature, ill keep my on from 6 seconds to 20 seconds and set my throttle at approx. 1000 rpms.
No cold weather. Have in 75 degree garage. 4630 does not have glow plugs
Thanks
   / Ford New Holland 4630 #4
Isn't there a small multi contact relay that energizes the fuel solenoid? I had a similar problem on my TC30 last year and found this relay contacts burnt. I opened it and took a business card and cleaned the points. No more problems since. Just thinking??
Already replaced with new relay
   / Ford New Holland 4630 #6
I'm as lost as you are now. I know your frustrated, but greasing the high lift fern docket may help!! :)). I'll go on UTube and see if I can find something.
Ok Let me know
Thanks
Lester
   / Ford New Holland 4630 #8
I've jus looked on UTube and find nothing. I'll talk to a buddy in the morning and get back to you,
Larry
   / Ford New Holland 4630 #10
My friend and I visited about your situation. You do know that the tank is clean, safety switches connections are clean and the switch(s) are functioning, the wire to the fuel pump is a good wire and has not been crimped and cut or insulation is off and wire shorting out, and fuel is not restricted from tank to pump.
I don't think I've helped cause I think you've already checked all is these things. Hope you find the culprit. Larry
2008 KOMATSU D39PX DOZER (A52577)
2008 KOMATSU D39PX...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
New/Unused 78in Quick Attach Rock Bucket (A51573)
New/Unused 78in...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
2018 Bobcat T-450 (A51573)
2018 Bobcat T-450...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
