Ford New Holland 4610 injector seals
   / Ford New Holland 4610 injector seals #1
scrimmi1
John Deere 950
Hello,
Has anyone ever changed the injector seals on a 4600 series 3 cylinder diesel? The torque spec lists 17 ft/lbs on the two 5/16-18 bolts holding down the injectors but 17 ft/lbs is about max torque for these grade 5 bolts before failure. I have them cranked down to 16 ft/lbs but it feels that they are just about "at the point of dare no further". The seals are thick cork type rings and I can hear and feel cylinder compression blowing through them when cranking. I was thinking of sealing them with RTV, but has anyone dealt with these type of gaskets? Seems like a poor design. Thanks
   / Ford New Holland 4610 injector seals #2
Those cork seals don't seal out the compression, they just keep junk from getting down around the injector. There's a copper washer down at the tip of the injector that does the real sealing, if you didn't change that or didn't install them then that's your problem
   / Ford New Holland 4610 injector seals #3
^^This.
Great, thank you
JOHN DEERE/UNVERFERTH 1700/330 LOT IDENTIFIER 13 (A53084)
JOHN...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2008 Caterpillar 45kW C4.4 3-Phase T/A Towable Diesel Generator (A51691)
2008 Caterpillar...
UNUSED FUTURE J5T TON 36" HYD THUMB CLAMP (A51248)
UNUSED FUTURE J5T...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
