Ford New Holland 4610 injector seals
   / Ford New Holland 4610 injector seals #1
scrimmi1
John Deere 950
Hello,
Has anyone ever changed the injector seals on a 4600 series 3 cylinder diesel? The torque spec lists 17 ft/lbs on the two 5/16-18 bolts holding down the injectors but 17 ft/lbs is about max torque for these grade 5 bolts before failure. I have them cranked down to 16 ft/lbs but it feels that they are just about "at the point of dare no further". The seals are thick cork type rings and I can hear and feel cylinder compression blowing through them when cranking. I was thinking of sealing them with RTV, but has anyone dealt with these type of gaskets? Seems like a poor design. Thanks
   / Ford New Holland 4610 injector seals #2
Those cork seals don't seal out the compression, they just keep junk from getting down around the injector. There's a copper washer down at the tip of the injector that does the real sealing, if you didn't change that or didn't install them then that's your problem
   / Ford New Holland 4610 injector seals #3
^^This.
Great, thank you
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A55787)
2025 GIYI VR66...
2021 CHEVROLET SILVERADO 2500HD (A55745)
2021 CHEVROLET...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
Electric Forklift Pallet (A50322)
Electric Forklift...
4-295/75R22.5 Tires And Rims (A50775)
4-295/75R22.5...
