Ford New Holland 1920 PTO hard to engage
   / Ford New Holland 1920 PTO hard to engage #1
ken mccubbin
Ratcliff AR
NH 1920, NH TC18D, International Bub Cadet 982, International Cub Cadet 782, Cub Cadet Corp 782, Case 446 w/ hydrolic tiller
I have a 2000 year model Ford New Holland 1920 compact tractor with about 1600 hours. It's equipped with 3 speed manual transmission and 4 speed transaxle with two stage clutch. The PTO has been getting hard to engage. If you idle tractor all the way down, wait a few minutes and press the clutch pedal as hard as you can it will engage fairly easy and quiet.
Any ideas? Some kind of relatively inexpensive adjustment or break the tractor and install new clutches?
Thanks, ken
   / Ford New Holland 1920 PTO hard to engage #3
I have the same issue If I find something out I will let you know
   / Ford New Holland 1920 PTO hard to engage #4
I had a Ford 1700 with a very similar problem. I had to hold the clutch in for 15-30 seconds to get a smooth pto engagement. From what I surmised it was to give the gearing time to spin down. I adjusted the clutch and the problem was corrected.
   / Ford New Holland 1920 PTO hard to engage #5
If the tractor has a double clutch (live PTO) then the clutch could need adjusted, or the clutch is bad and needs replaced. I do not know if the little fords had an inspection cover for the clutches or if the tractor would need split.
Clutch adjustment was the fix. Found instructions in (of all places) the owner's manual. Sheesh, sorry......Thanks ken
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2020 JOHN DEERE 5125R LOT IDENTIFIER 198 (A53084)
2020 JOHN DEERE...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
J BAR SD5 5' ROTARY MOWER (A51247)
J BAR SD5 5'...
