Apr 29, 2023 / Ford M1C137-A Equivalent #1 GSVette Gold Member Joined May 22, 2017 Messages 409 Location Spokane, WA Tractor LS XR4155HC, Case 580D/E Need to drain and refill the gearbox on my Ford 917 flail. M1C137-A is what is called out- what is the closest equivalent?
Apr 29, 2023 / Ford M1C137-A Equivalent #2 N number two Veteran Member Joined Apr 2, 2007 Messages 1,287 Location Northern Lower Michigan Tractor Kubota B3030HSDC Kubota L2501HST Don't know the spec,but it sure looks like an 80W90 gear lube would be the ticket. Good Luck!
Apr 30, 2023 / Ford M1C137-A Equivalent #3 T TractorTech Veteran Member Joined Jan 26, 2012 Messages 2,360 Location California Tractor Ford 7710, Ford 550, Ford 1910, Ford 4430, KD Forklift, Ford LGT17H, New Holland L255 Skidsteer 80w90 gear lube should work, but a gearbox grease is closer to the M1C137-A.
