Ford Industrial 2000 (~1963)
   / Ford Industrial 2000 (~1963) #1
JCornwall
Phoenix, AZ
I have the above tractor and live in the Phoenix area. It's a model 20302, S/N 154543 with front loader and 3Pt hitch. I'm currently trying to restore the hydraulic steering, as the hyd fluid spews out through to steering column. I removed the steering column and shuttle hardware and see the seals, however I have no idea where to procure the seals.
Any ideas would be appreciated.
   / Ford Industrial 2000 (~1963) #2
The parts you need are listed in the New Holland diagram below.
You will want to replace both the upper #44 and lower #28 seals.
I always buy two of the orings #32.
It is not a hard job but you will need to remove the tin to get at it. Pay particular attention that all the balls and plungers do not fall out of the power block when you remove it from the column. You will need a I&T FO-20 manual to reassemble it correctly.
I just call my local CNH dealer and have the seals sent to me.
Edit: Inspect the surface area of the shaft where the upper seal rides. If it is worn or pitted you can buy a speedi sleeve to repair it.
Official New Holland Online Parts Store and Online Parts Catalog for New Holland and Ford Tractors.
Thanks for the information, I think it will get me where I need to be. Any idea where can I get a FO-20 manual?
Thx again-
   / Ford Industrial 2000 (~1963) #4
:welcome:
To TBN JCornwall. Pictures along the way will help others with similar problems.
   / Ford Industrial 2000 (~1963) #5
Thx again-
Try google. There are about a million places to buy one.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Freeman Bros 200 Gallon Fuel Tank (A51573)
Freeman Bros 200...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
1997 International 9300 Day Cab Tractor (A52384)
1997 International...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
