Ford flail mower 917 advice
   / Ford flail mower 917 advice #11
FYI 917 (Bush Hog FH174 or FH188 also) the skid shoes that go on either side are no longer available.
Here is a drawing of them.
They come from the factory with 5/16” plow bolts. However I couldn’t get any, so I used a 3/8” flat head cap screw/bolt.
I used 1.5”x.25 strap steel 36” long to make replacement skids.
Bush Hog said they made the 917 for Ford.
   / Ford flail mower 917 advice #12
Thanks for sharing the skid drawing. The old skids can be used as a pattern, but this is great. And, as you show, it is not critical to use plow bolts as the bolt is just holding the skid in place. At one point, when I could get the skids for a decent price from Flail Master, I used carriage bolts, heated the head and pounded the head flat.
   / Ford flail mower 917 advice #13
I called Flailmaster first to get the skids and they said they no longer have them. I don’t doubt the demand for them is low likely very low.
   / Ford flail mower 917 advice #14
Right, like I said in an earlier post, they no longer sell them and yes, low demand most likely. Thanks for sharing the drawing.
When I make up a set, I will go with thicker material.
2 Chains and 4 Binders (A51573)
2 Chains and 4...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
