Ford Flail 907 Driveshaft
   / Ford Flail 907 Driveshaft #1
mtnxtreme
Does anyone have the specs for the driveshaft for a 5 foot Ford Flail 907, as far as length etc. I'm thinking 1-3/8" spline both ends, but no idea on length. Of course I bought this mower, and it had no driveshaft !
Darn, no one has this mower ?
   / Ford Flail 907 Driveshaft #3
Hook it up to your tractor and get your tape measure out. Go buy a generic metric Series 4 driveshaft with the appropriate implement end yoke and 1-3/8"-6 tractor end yoke of a suitable length. Cut to the exact length you need.
It needs to have a slip joint,correct. how do I measure where the slip should be and with mower up, down, should I run an override coupler ?
   / Ford Flail 907 Driveshaft #5
A complete replacement PTO shaft will be a telescoping shaft. Measure shaft to shaft with the mower fully raised and fully lowered. Usually but not always the longer measurement will be with the implement raised. You want a minimum of 6" of overlap at the longest point and some room for the shaft to collapse a bit more at the shortest length.
Do a search for "measuring and cutting a PTO shaft" there are a bunch of videos.
I wouldn't run an ORC on a flail mower, there isn't enough inertial energy to concern me.
   / Ford Flail 907 Driveshaft #6
I agree with Rick, no need for an orc on a flail, and most newer tractors have them built-in to the pto drive.
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
Skid steer auger plate (A50322)
Skid steer auger...
2012 CHEVROLET EXPRESS (A52472)
2012 CHEVROLET...
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
