Ford Flail 907 Driveshaft
   / Ford Flail 907 Driveshaft #1
mtnxtreme
Bronze Member
Does anyone have the specs for the driveshaft for a 5 foot Ford Flail 907, as far as length etc. I'm thinking 1-3/8" spline both ends, but no idea on length. Of course I bought this mower, and it had no driveshaft !
Darn, no one has this mower ?
   / Ford Flail 907 Driveshaft #3
Hook it up to your tractor and get your tape measure out. Go buy a generic metric Series 4 driveshaft with the appropriate implement end yoke and 1-3/8"-6 tractor end yoke of a suitable length. Cut to the exact length you need.
It needs to have a slip joint,correct. how do I measure where the slip should be and with mower up, down, should I run an override coupler ?
   / Ford Flail 907 Driveshaft #5
A complete replacement PTO shaft will be a telescoping shaft. Measure shaft to shaft with the mower fully raised and fully lowered. Usually but not always the longer measurement will be with the implement raised. You want a minimum of 6" of overlap at the longest point and some room for the shaft to collapse a bit more at the shortest length.
Do a search for "measuring and cutting a PTO shaft" there are a bunch of videos.
I wouldn't run an ORC on a flail mower, there isn't enough inertial energy to concern me.
   / Ford Flail 907 Driveshaft #6
I agree with Rick, no need for an orc on a flail, and most newer tractors have them built-in to the pto drive.
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
