Ford F-Max class 8 tractor
   / Ford F-Max class 8 tractor #11
Do you guys see a market for it in North America ?
Short answer is no. Cabover big trucks are rare, as are 2 axles. Two axle trucks are limited here and require a set of doubles to get 80k gcw. Every state is slightly different. So to go coast to coast, you need to follow the most restrictive state, in your route. The standard is 5 axles total or 34k per tandem and 12k steer axle, that gets you 80k. A spread axle trailer (10') can get you 20k per axle but still only 80k total, in some states. Some states will allow the 20k per axle for a total of 86K. Some states will allow Rocky Mountain Doubles, or two full size trailers but they have to stay within the states that allow it.
Big truck rules are brutal here, so that is why I quit them in '92 after 20 years. Now I run non-cdl hotshot, 26k max.:)
   / Ford F-Max class 8 tractor #12
AND big truck fines are brutal.
I know. The axle thing, that can be arranged as Meritor and others offer plenty of OEM choices. Scania also put a hood in front of their cabover cabs, and i dont know if they swap the tunneled floor for a flat one on hooded versions..
But would Ford develop an engine for Europe (allmost the same emission standards as the USA) and not use it in a USA built truck as well ?
Paccar is now using the Dutch developed Daf engine in Kennies and Petes, to spread the development costs over more units... would Ford do the same ?
   / Ford F-Max class 8 tractor #14
It would have to be a different platform to sell in th US. I don’t think you’ll find much enthusiasm for a cabover, especially in the western part of the country. I haven’t driven one since the late 80s. Cabovers are about like hen’s teeth - pretty rare and for good reason. It’s so much easier to tilt a hood than to jack a cab up. They might have a small market as city delivery trucks.
But then, city delivery doesnt require a 500hp 12.7 liter engine, does it ?
What you see is Volvo sharing technology between their European and American branches. Paccar using the European Daf engine in their American trucks. Detroit Diesel building European Mercedes Benz engines. Navistar used to build their MaxxForce 13 based on European MAN tech, which will inevitably return now the European members of Traton (VW) group, MAN and Scania are sharing a new 13 liter platform.
Vertical integration is the norm in the truck world. So Ford developing a brand new Diesel for their European (west Asian) truck works is an unusual move, especially since they sold their bigger truck lines to Freightliner years ago...
   / Ford F-Max class 8 tractor #16
There’s quite a few coke, Pepsi or beer delivery trucks that are single axel. But I agree a single axel cab over isn’t going to be a big hit in the US.
   / Ford F-Max class 8 tractor #17
You really don't lift the cab on a cab over that frequently. Only if you have a major issue on the engine that requires taking things apart there.
All of the daily maintenance stuff is easily accessible by lifting a front panel up. Even still, these newer trucks will most likely have some sort of electric pump to lift the cab with a flick of a switch.
   / Ford F-Max class 8 tractor #18
Even once a month is too much. Can you say, secure/remove all your belongings before you tilt. Such as your steel thermos, very hard on windshields:p
   / Ford F-Max class 8 tractor #19
We would rather have the slight inconvenience of putting the stuff back in the proper storage spaces so kindly provided by the manufacturer than needing three football fields to make even the slightest maneuver and still won't fit on most places. 😁
And we do have plenty of axles for heavy loads too, most are able to steer.
   / Ford F-Max class 8 tractor #20
Nice load. I guess each design has its place. Unlike highways in much of Europe, we generally have room to maneuver “three football fields” to get around. 😂
My retirement job is driving grain trucks during harvest. Conventionals are so much easier to get in and out of. Plus, those cabovers are too tall for the auger on a grain cart to clear and would be a pain for the cart operator.
Three football fields? 🤔
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2019 Ford Explorer AWD SUV (A56859)
2019 Ford Explorer...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A55973)
2012 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Elgin V2403-CR-T Broom Badger Sweeper, S/N V2903-7JV8496, Kubota Turbo Diesel Engine, High (A59076)
2019 Elgin...
Air Compressor (New/Unused) (A59225)
Air Compressor...
