Ford F 250 LED driving lights
   / Ford F 250 LED driving lights #1
elginfarm
Southwest suburb of Chicago Area
JD 4400
Hello All, Has anyone changed out the driving/ Fog lights on a Ford Superduty (F250/ 350) with LED lights? If so, what brand and size of light did you use? Were you able to bolt them right in or were modifications necessary. I would like to keep the factory look but get the advantage of the brighter lights.
Thanks for your responses and advice.
   / Ford F 250 LED driving lights #2
I ordered some Baja Designs Squadron Pro combo Amber lamps for my 2015 F350. They will replace the factory fogs.
   / Ford F 250 LED driving lights #4
One thing I have done to my 2007 F250 is alter the wiring to allow the use of high beams and fog lights at the same time.
The only time I ever use both is on secluded country roads to / from hunting or fishing usually. It does really light things up.
In a nutshell, the fog light relay is grounded thru the little HIGH BEAM light in the instrument panel that comes on with the high beams. By grounding this wire to chassis instead they can work at the same time.
   / Ford F 250 LED driving lights #5
Mine showed up yesterday.
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
WOODS TBW15.40 LOT NUMBER 243 (A53084)
WOODS TBW15.40 LOT...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
