Oil & Fuel Ford Dexta 2000 with 3 cyl Gas?
   / Ford Dexta 2000 with 3 cyl Gas? #11
Farmwithjunk said:
Here's a picture I located on a British farming site. 2000 "Dexta"
IMG_2026__Large_.jpg @ Fotopic.Net
Yep.. lamp in grill are what i say in some of the pics i found, and I'll bet it may even have a handbrake on the left side too.
soundguy
   / Ford Dexta 2000 with 3 cyl Gas? #12
I'm jealous. That thing has the dual range transmission. My '69 2000 only has a single range 4-speed....probably only the upper 4 speeds of the dual range. Great little tractor with a very strong engine...BUT NO REAL FIRST GEAR :( (or second, for that matter).
Good on the road though.
Did I see an alternator on that tractor? Wonder if that's a retrofit? Thought the Thousand series Fords all had Lucas generators with a built in mechanical tach drive. Electrically they seem to be alright when the mice leave them alone.
Bob
   / Ford Dexta 2000 with 3 cyl Gas? #13
Up till at least 75 they had lucas gennies.. though alternator kits were/are available to easilly retrofit anything 53 and up..
Soundguy
Bob
You are spot on about the alternator, and so is Soundguy. The previous owner of that tractor switched the system over.
   / Ford Dexta 2000 with 3 cyl Gas? #15
When the 6X series was first introduced in the fall of 1964, the 2000 was the 2000 Dexta, the 3000 was the 3000 Super Dexta, the 4000 was the 4000 Major, and the 5000 was the 5000 Super Major. At that time the 6000 was designated as the Commander 6000. Within a couple of years we were back to the basic 2000, 3000, 4000, 5000 designations.
1111-A (A54756)
1111-A (A54756)
1750 (A58374)
1750 (A58374)
Deere 335P (A53317)
Deere 335P (A53317)
INGERSOLL RAND SD25F PADFOOT ROLLER (A52709)
INGERSOLL RAND...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
LOT: (3) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (3) Kimball...
