Ford d5nn6015g
   / Ford d5nn6015g #1
INDSAM
kelowna
ford
Hi Everybody
I recently bought a Ford tractor with *D5NN6015 G* Serial no. can any one help me find the model no. and specs on it as I can`t find any thing due to the condition of the hood
Thanks
   / Ford d5nn6015g #2
G'day Indsam and :welcome: that number you have is a part no to me, I am guessing it is cast into the block ( raised lettering) you need to find the number that is stamped into the block ( recessed)'
jon
   / Ford d5nn6015g #3
Yep. Thats the block casting number. Anything that is cast or raised lettering isnt going to be a serial number. The serial number would be stamped somewhere. Usually on a machined flat spot around the starter. And there should also be a model code and date code there as well that will tells us all we need to know.
Any pictures. That will help us a ton.
   / Ford d5nn6015g
Thanks for the feed back then it would be *D275327* hope that works
   / Ford d5nn6015g #5
Any pictures of the tractor as a whole?
For us average joes (without a dealer connection or ability to decode the serial #) we have no idea what model that is from.
I believe that block is a 201CI 3-cylinder used in the 4000-series
And while that does indeed look like a serial number, the D in the front isnt jiving. Should start with a C or B?? But I am no ford expert. There should be a flat somewhere around the starter with a serial number similar to that, as well as a model code, and a date code. Is there anything there around the starter??
   / Ford d5nn6015g #6
Look on the transmission just above and behind the starter.
Should be 3 lines of numbers/letters there.
Post those and someone should be able to help ID it for you.
A picture of the tractor would help us ID it too.
   / Ford d5nn6015g #7
ditto what UD said. quit focusing on the block and focus ont he trans bellhousing.
that and / or a picture of the tractor will help ID it.
   / Ford d5nn6015g
Here are some pics that might help thanks
   / Ford d5nn6015g #9
on my phone those lil pics look like a 4000 ish something can't see the front spindles or final drive area good enough
   / Ford d5nn6015g
Thanks for the feed back I will post some more pics
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2023 JOHN DEERE 8R370 LOT NUMBER 201 (A53084)
2023 JOHN DEERE...
POWER LINE 180 LOT NUMBER 89 (A53084)
POWER LINE 180 LOT...
2005 TRANSCRAFT 48 X 102 FLATBED (A52472)
2005 TRANSCRAFT 48...
WIGGINS 5K FORKLIFT (A52472)
WIGGINS 5K...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
