Ford-Cummins
   / Ford-Cummins #11
At one time Ford had about 7% of Cummins but have since sold it. The time frame for this is ??? maybe 8/10 years ago.
Egon
   / Ford-Cummins #12
I don't think you will see a 5.9 Cummins in a Ford F250-550..
The engine in the Brazilian Ford website appeared to have an old style rotary injection pump, not an electronic pump they use now. The 7.3 Powerstroke is the same engine that IHC uses in their trucks (called a T444E). 444 cu in, turbo-electronic.
   / Ford-Cummins
This is my guess. They are looking for an engine to put in there F650-750 series trucks, it would not make much sense to buy an engine from who they are competing against(truck wise) in the same market.
   / Ford-Cummins #14
International does use the powerstroke in their medium duty trucks. The new 6.0 powerstroke was used exclusively in International medium duty trucks for 2 years before it even was released in the Ford. I'm not saying that the cummins isn't a great engine by any means. Ford did want to offer a choice between the cummins and the powerstroke. But Dodge purchased the exclusive rights for the cummins in the light duty truck market. As far as Ford in their medium duty trucks you actually have three choices. There is a cat motor, the cummins, or the powerstoke.
   / Ford-Cummins #15
This is what AutoWeek had to say about the supply of diesels for the F-150 in the December 10, 2003 issue. It also tells what suppliers thought about supplying to Ford. AutoWeek Ford Diesels
   / Ford-Cummins #16
Around 1961 or so, GM offered a small diesel, I believe it was a 4 banger in the GMC pickup. It just didn't sell. Those were the years when the GMC had a 301 and 351 cu in gas V-6.
The 5.9 Cummins is pretty heavy for a "half ton" truck. It's about 500 lbs heavier than a gasoline V-8.
There's probably a good market for a smaller diesel for a "half ton". I'd buy one once they are perfected.
   / Ford-Cummins #17
The next dawg we're going to see marketed in the light truck market is going to be a Durango--Colorado sized diesel with either this or another motor awful similar.
If you'll notice your local UPS in the rural areas are using these puppies and they have a GVW in the neighborhood of eight thousand pounds, have a five cylinder diesel with lots of pep and a five speed automatic trans. If I was in a business where a van body worked for me I'd look at one of these real close.
But that same motor and trans would do just fine in a half ton.
Mercedes buying Chrysler and then refusing to chryslerize mercedes and instead mercedesing chrysler might be a good thing for the consumer in the long run.
   / Ford-Cummins #18
</font><font color="blue" class="small">( This is my guess. They are looking for an engine to put in there F650-750 series trucks, it would not make much sense to buy an engine from who they are competing against(truck wise) in the same market. )</font>
The Power Stroke is the standard engine in the 650-750 series, but Cummins or Caterpiller engines are available as options.
   / Ford-Cummins #19
My son and I stopped by a Dodge dealer this past weekend and found the MB Sprinter Vans, mentioned above, being sold as rebadged Dodges.
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
HIGH END MINI GOLF CART (A58216)
HIGH END MINI GOLF...
CASE MXM 190 TRACTOR (A58216)
CASE MXM 190...
2211 (A58376)
2211 (A58376)
2370 (A58376)
2370 (A58376)
2016 Komatsu PC240 LC-11 Excavator (A59213)
2016 Komatsu PC240...
