Ford Brake Shoe interchange
   / Ford Brake Shoe interchange #1
fairview887
Vermont
Ford 3400
Does anyone out there know whether the 2" brake shoes from a 3500 ford tractor will direct fit in place of the 1 1/2" stock shoes on a 3400 Ford Utility? I have had several conflicting answers. It appears looking up on various parts diagrams that all related parts are the same. I want the wider, heavier shoes due to my mountainous woodland.
Thanks for any help...Bill
   / Ford Brake Shoe interchange #2
The first thing that comes to mind is if your drums have ANY wear as a result of having 1-1/2" shoes running against them, 2" shoes will have minimal braking action. The short answer is yes, the 2" shoes will fit. How they will work is questionable.
Brakes havn't worked in a LONG time due to oil seal leaks. I don't think drums are worn , but I assume you mean a 1 1/2" wear area from the old shoes. Seems a good clean up and sanding should take care of all but a very serious wear pattern.
Thanks for your input!
   / Ford Brake Shoe interchange #4
What Rick is saying is that if you have any wear from your 1 1/2 shoes and you put a 2" shoe on it you will only have 1/2" of shoe contacting the drum.
Bill
   / Ford Brake Shoe interchange #5
It's pretty optimistic to think that brake drums that are 30-40 years old have no wear. Fix the seals and replace the 1-1/2" shoes with new shoes of the same size and see what you have.
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
