ford backhoe swing cylinders
/ ford backhoe swing cylinders #1
dirt dog
Alapaha, Ga
81 ford 555 bachhoe
I have a 81 ford 555 special backhoe. The dipper will swing to the right, but will only return back to the center. I have had both cylinders repacked but this still happens. The left cylinder will not retract. I swapped the two lines at the rear of the cylinders, but this moves the problem to the other side. Could the cushioning valve on one of the cylinders be bad. Everything else works fine. Any help or thoughts will be deeply appreciated.
/ ford backhoe swing cylinders #2
On Edit:
Scratch that. The 555 is completely different than the 753.
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
INGERSOLL RAND 80 GALLON COMPRESSOR (A65643)
INGERSOLL RAND 80...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
